Question about Dell Microsoft Windows XP Home Edition
Dell 4550 unmountable boot volume error.
We lost pwer one night and now when the system goes to boot. All we get is the BLUE SCREEN OF DEATH. Using the F8 and F11 options it always goes to the same screen with 5-6 different options. And no matter which one you use it always comes up unmountale_boot_volume_error. I know there has to be a work around. But I do not know how. HELP, Bob
  • stargazer54
    stargazer54 Jun 15, 2008
    Thank you very much for getting me on the right track. What I ended up doing was using the install cd. But I had to use the F12 button and type HELP in the promt. That brought up a list and I used FIXBOOT. About 15 min. later back up and running. Once again Thank You. Bob
  • stargazer54
    Thank you. I plan to buy an external hard drive in the morning. I will load a copy of the OS and some important files I have on there. And yes I will disconnect it and LOCK it up. Thanks, Bob
  • 150 Answers
0) Your hard drive is corrupted by improper shut down,
or the hardware may be physically damaged by
by a power spike.
1) Reboot the machine with hard reset, and press the BIOS
key during the memory test.
Typically this is the DEL key most machines but it could
be F1 or some other key, so if DEL does not get you into
the BIOS, check you system manual or experiment.
2) Once you are in the BIOS settings screen, look for a
TAB or settings page for changing the BOOT priority
for installed devices.
3) Make sure that your CD-ROM drive is FIRST in line, before
the hard drive, but leave the hard disk boot enabled
4) If you do this correctly your system should firs try to boot
from the CD, and only try the disk if the CD is not in the
5) Now reboot the machine from the original Windows setup
CD, and let it do its thing, until you get to a prompt
asking you id you want to RE-INSTALL Windows or
try to REPAIR the installation using a RESCUE DISK
for now, choose INSTALL, and accept the user license
6) Proceed with the installation (only) until you get another
prompt, asking you if wish wish to repair the system
using the
7) Chose the recovery console !!!
(do not continue with a new install)
8) After windows finishes loading, you will be looking
at a black and white text screen, similar to DOS.
9) You may have to login with the administrator password.
10) If your master administator password is lost or unavailable,
and if you are using windows XP, try to get it with
and older Windows 2000 installation disk instead,
This should get you beyond the windows XP password
security and function the same as XP.
11) Once you are logged into the recovery console, you
can try to repair the master boot record on the damaged
12) Type FixMBR at the command prompt
for more info read this Microsoft article:
13) If this does not work, then the Windows partition is
corrupt. The problem is that most tools needed to repair
NTFS require Windows to run, and Windows will NOT run
if the boot partition is bad.
14) To get around this problem, you can install a second
hard drive in you machine, and install a parallel copy
of windows on it.
or if your existing drive is partioned, you could use
a tool like Norton's Partition Magic to adjust the partitions,
such that you could make a new partition for the parallel
copy of windows there, put keep in mind that you Partition
Magic will NOT alter any partition that is damaged, so
you may have a Catch 22 situation.
15) Once you have a parallel copy of windows installed on the
machine, you can use a multitude of tools to try to repair
the damage hard drive, MBR, partition tables, partion boot
records, the file system ... etc
At this point you can also replace key windows system files
by copying them over from good windows to the bad.
16) There are also (expensive) commercial utilities for
recovering corrupted disks. NTFS is more expensive to
recover than FAT
17) Finally is non of the above works, you can sent your
drive back to the manufacturer or a professional
recovery lab, this cost $2000 to $3000 though.
18) Not all drives can be recovered fully, depending on how
bad the damage is.
19) If the hard-drive electronics are damaged from a power
spike, it is often possible to service the hard drive by
replacing its circuit board, from an identical model,
because the data is probably still intact. An electronic
tech can easily do this. This is cheap.
20) Always run you computer from a UPS, uninteruptable
power supply (battery backed up) to prevent such
problems in the future.
Hope this helps
Posted on Jun 09, 2008
  • Martin J Stadler
    Martin J Stadler Jun 15, 2008
    I still very much recommend partitioning your drive,
    and creating duplicate windows installations, as
    well as hidden back-up partitions.
    Use Acronis Tools to do this.
    It will save you a lot of future time and grief.
    Another good idea is to image your internal drive to an
    external USB drive for back-up, and then shut of the external
    drive, and keep in in a safe place until you need it.
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
My DEll D505 has the blue screen of death which says unmountable boot volume and I do not have the reset disc. I do no know what to do. Please Help...
In that case borrow an Windows install disk from a friend and using your own key reinstall with it. After that you will have to install the drivers yourself. You can download them from here
Sep 26, 2010 | Dell Latitude D505 Notebook
I have a code 7
If this issue can be fixed, a good start is going to be..
Boot from your windows installation cd, then access the recovery console.
At the command prompt your going to need to run chkdsk /r
here is a link to microsoft that goes into greater detail on this issue.
Apr 22, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Blue Unmountable Error Screen
Mar 08, 2010 | Dell Inspiron Mini 10 Notebook
Pavilion ze4600 will not start
The blue screen that you see is what they call "the blue screen of death". The error that you have is Unmountable Boot Volume. This is caused by the operating system not being to load due to hard drive errors. This happens due to the computer being shutdown improperly or hard drive problem. I suggest that you contact the manufacturer of the computer so they can try and restore the computer without formatting or changing the hard drive.
Jun 10, 2009 | HP Pavilion dv6000z Notebook
Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Blue screen of death
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Operating system
What part do you usually get the blue screen, you also need to know what kind of blue screen are you getting, for example beginning dump of physical memory or unmountable boot volume, then send me a message so that i can help you.
Nov 03, 2008 | Dell Microsoft Windows XP Home Edition
Computers & Internet Logo
619 people viewed this question
Alun Cox
