Question about Arris DSR922
Loss of satellite positioning after power off at night
Have reprogrammed all sats 4 times in 4 days works fine all day moving from top of arc to bottom after turning off at night cannot get a sat in the am , I wrote down the counter positions and it returns to the same # but this can be up to 94 counts off the satellite when i reprogram any ideas
Hi I could be the arm is slightly loose and is sliding a bit each time you use it. Tighten everything. Also the reed switch might be breaking down. It's easy to replace as it's the only component on the sensor wires. Good luck
Posted on Jul 01, 2008
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
Vip 722 looses programming
Jeff Koryciak,
I apologize for any frustration with the recordings being deleted. Signal loss doesn't affect the recordings already on the hard drive, however if it's deleting every day it sounds like the hard drive is about to fail.
We can definitely send you a replacement receiver. I would also recommend using an External Hard Drive to backup and store recordings to avoid losing them in the future. If you would like me to look into a replacement, you can shoot me an email at thomas.faust@dish.com.
Tommy Faust
DISH Social Media Representative
Jun 14, 2012 | DISH Network Televison & Video
I HAVE DISH NETWORK RECEIVER #322 AND ON TV 2 I CAN NOT GET PASSED THE DISH NETWORK PRESS SELECT TO CONTINUE SCREEN. THE DISH REMOTE IS PROGRAMMED FOR MY TV AS ALL OTHER BUTTONS WORK (POWER ON/OFF, VOLUME...
Hello! My name is Becki Barned, and I am from Dish Network customer service. The problem that you are having is simple to fix. Although your remote works for the volume, and power, it is not working for the satellite. It does need to be reprogrammed. Just take it to tv1. With your tv1 remote, press the menu button twice. Then with the tv2 non-working remote, hold down the SAT button until all the mode lights light up at the top, then release. Then press the #9 on the remote keypad, then the pound (#) button, then record (above the number 3 on the keypad) 3 times. This should resolve your issue!!! If not, you can blog back, or find us on Twitter!!!!
Dec 23, 2010 | DISH Network 322 DTV Receiver
Dish Network 322 will not work both TV's at the same time. If TV1 is on it works fine, but TV2 says aquiring satellite signal. If TV2 is on it works fine, but TV1 will say aquiring satellite signal. Both...
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
Jun 25, 2010 | DISH Network 322 DTV Receiver
322 receiver trying to acquire a sat signal for 5 days 0 out of 5 progress please help
Hi, Mary with Dish network Customer Service. The issue you are experiencing is a complete satellite signal loss message. If you are experiencing severe weather right now it is best to wait till it passes. Then you can reset the receiver box by unplugging it for 10 seconds from the power and then allow it to reboot. Also check all the connections in the room with the receiver box from the wall up to the receiver itself. If it does not get off 0 progress of 5, you will need to call Dish network and will probably need a Service Technician Visit scheduled.
Apr 17, 2010 | DISH Network 322 DTV Receiver
No satellite signel - we were watching a program -
while ice can cause signal loss, there is a simple test to determine if there is an inline signal problem.
press MENU - 6 -1 - 1 and select check switch, then select test...
it will start at Testing 1 of 1.. then will change...
if it changes to 1 of 3 there is either something (ice) blocking the dish or the dish is no longer aligned.
if it goes to 1 of 38 the dish is no longer connected to your receiver.
Jan 29, 2010 | DISH Network Televison & Video
Satellite works fine in the day but no signal in
I have run into this problem a couple of times, once a loose connection at the LNB, other times it has been due to moisture build up (dew) in the loose connections, check all connections from the LNB through the tuner, and any other devices involved (a line map maybe?) that will most likely resolve the problem.
Sep 15, 2009 | Televison & Video
NOT CORRECTLY IDENTIFY SAT
The HD feed comes in on 61.5 for a majority of stations most often locals come off 119 or 110. The USA hd comes off of 61.5 transponder 19.If you press menu 611 on your dish remote and manuever the highlight to the satellite and go to 61.5 and then change the transponder to 19 you will probably have a poor signal from 0 -39. Typically this can be resolved by having the dish re-peaked but sometimes foilage may be the cause. Thanks for using Fix Ya.
Aug 02, 2009 | DISH Network 301 DTV Receiver
Lost signal from the satellite
Signal Fade And Loss ~ Important, especially during winter!
Keep in mind that satellite broadcasts occur directly from fixed satellites in space to users. UPLINKS TO that satellite can happen from almost anywhere in the world! This includes broadcasts from remote studios, satellite vans and trucks.
Even signals from the main providing studios are susceptible to weather conditons even tho they have huge, high-gain transmitting dishes!
Weather is a major factor for both the uplinks and downlinks! Storm clouds can block the signals anywhere in the signal path(s). Rain clouds do too ~ even if it's not raining yet. Water-laden clouds make some of the BEST signal attenuators.
So one may have a gorgeous day in San Diego (let's say), but storms back east could trash satellite reception at his location and potentially everywhere else!
As you know, weather conditions all over the US are changing constantly with many severe storms occurring this past week and during any winter. In fact this week there was total signal loss on several satellites and I suspect storms back east were a big factor.
So it could have just been issues of timing for you. The UPLINK had intermittent problems with signal paths semi-crippled by weather... YOUR weather was CLEAR, but your reception was far from problem free ~ only because of weather problems elsewhere.
If you see intermittent satellite reception do check out the weather... especially back east.
Hope this helps!
Feb 01, 2009 | DISH Network Televison & Video
Cannot change/move satellite
I assume this is an outdoor satellite dish system, like a c-band system? It sounds like the motor drive outside has a stripped gear on the main shaft. The motor is probably running and the sensor wheel is turning (making the unit in the house think the dish is moving) but the screw shaft is not turning.
Hope that helped
Geno
Jul 29, 2008 | Arris DSR922
Televison & Video Logo
Top Arris Televison & Video Experts
Electro Med Services...
Are you an Arris Televison and Video Expert? Answer questions, earn points and help others
