I get the warning virtual memory minimum too low how do i fix this
    President:
  • 1,257 Answers
Very simple .just goto control panel >Double click on system >Select Advance tab >Under Performance tab click on Settings >Select Advanced >Under Virtual Memory tab click on Change,
Now select custom radio button
Now you will some thing like this
Initial size(MB) = 768
Maximum size -1024
Now here comes the main point and to enter proper values under Initial size (MB) =
and Maximum size =
suppose your ram is of 512 mb than initial size will be
Initial size = 768 ( 512 * 1.5 = 768)
Maximum size = 2304 ( 512 * 1.5 * 3 = 2304)
just enter the values according to calculation and your problem is solved ..if you want you can increase more 'Maximum size' value for faster system optimization .
_____________________________________________________
Was this solution helpful .Show your appreciation by rating it.
dilipbagdi - Technical Associate
Posted on Jun 08, 2008
My pc is running low on virtual memory when i use the internet
In general, you want to set your minimum virtual memory to about 3 times the total amount of memory installed in the machine.(3072MB for each gig of ram) The maximum should be 4096 more than the minimum setting.
To check this, right-click on "My Computer" and choose "Properties". Click on the "Advanced" tab and click the "Settings" button in the "Performance" section. On the "Performance Options" panel, click the "Advanced" tab. The virtual memory button is at the bottom (on xp machines). Selcect "custom" and then set the values according to how much ram you have in the machine. For more, check here.
http://www.thermwood.com/forums/viewtopic.php?f=3&t=897&hilit=virtual+memory
Oct 08, 2011 | Computers & Internet
Windows-virtual memory minimum too low. your system is low on virtualmemory.windows is increasing the size of your virtual memory plugin file.during this process,memory request for some applications maybe...
Right-click 'My Computer' and select properties.
Click 'Advanced' tab.
Click Settings button.
Click 'Advanced' tab. Click 'Change' button.
Select 'System managed size' and click 'Set' button.
Click 'OK' buttons to close all dialog windows.
This will correct your problem.
I hope will vote my answer.
Sep 12, 2011 | Computers & Internet
Virtual memory low, not sure how much I have got and what I can upgrade to? My desktop ser no is 11419107876?
I assume that you got a little balloon in the
bottom right-hand corner announcing that your
virtual memory is low and that Windows is
adjusting it. If this happens just once, don't
worry.
As the message said, Windows found a problem
and fixed it. But if it happens repeatedly,
it could be that your settings don't allow
Windows to make the necessary adjustment.
First, make sure your drive isn't overly full.
In Windows Explorer, right-click the drive
icon and choose Properties.
If the amount of free space is under about
10 percent, you'll need to free up some space.
You can use the Disk Cleanup button right next
to the free space indicator, or manually move
some files to off-line storage,
or uninstall unnecessary applications whatever
it takes to get more free space.
If low drive space isn't the problem, the
virtual-memory settings may be wrong.
Right-click My Computer and choose
Properties. Click the Advanced tab.
Click the Settings button in the
Performance panel.
Click the Advanced tab in the Performance dialog.
Click the Change button in the Virtual
memory panel. Whew! This setting is buried
quite thoroughly!
Look for the System managed size option,
select it if it isn't already selected,
and then click OK, OK, OK. That should end the
warnings.
Aug 17, 2010 | Targa Computers & Internet
My comuter say it is low on virtual memory and windows is increasing it. This is the 3rd or 4th time it has happend in the last month. Is there something I need to do. It is on automatic scanning. I have a...
Virtual Memory is the space Windows uses to put information on your Hard drive when there is not enough RAM ( your 512Mb DDR2) to hold it.
To change this you need to Right click on "My computer" and select "properties " click on the Advance tab then click on "Performance/Settings" once in the perfomance section click on "Advanced" again and down near the bottom you will see "Virtual Memory" click on "Change" this will take you to a page hat will show you your C drive and the Paging file Size ( Virtual memory) near the bottom of this pag you will see a minimum allowed a recommended and a currently allocated. above this you need to select "Custom Size " and in the initial size enter the currently allocated number then for the maximum size enter the "recommended" number. Click on "SET" then OK 3 times. You will need to restert your computer for these changes to take effect and once done you should not receive that warning again.
Hope this helps
Jul 25, 2010 | Dell Dimension 4700 PC Desktop
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
Cant get past error even tryed to repair windows or how can i install reinstall
Try booting into safe mode by pressing F8 when boot up starts. Choose safe mode. When it's booted up, right click on "my Computer" and choose properties. Click on advanced and choose the advanced tab. Go to performance and change the settings of Virtual Memory to what Windows Recommends.Restart.
May 29, 2009 | Gateway Essential 400 PC Desktop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Virtual Memory error
Dear
Right click on My Computer icon .. go to Properties->Advanced->Setting->advanced->Change..
THan Select Drive go to Custum Size Fill Minimum an Meximum virtual ram size remember u fill double ammount to ur actual ram size like 512-1024
Click Set ok  and restat ur pc
Oct 19, 2008 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
