Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 3347 Hello, Do you know how the Netopia 3347 needs to be configured to communicate with a SonicWall TZ170? I have the settings for the SonicWall, but I am not sure of the Netopia. I can access the netopia remotely. Thanks
Http://www.netopia.com/support/hardware/technotes/CQG_042.html
I was actually able to speak with Netopia and they recommended CQG_042 technote. The link is above.
Thanks for responding though.
Posted on Jun 14, 2008
No i dont sorry. if i had the two i could find out but i dont have access to any. sorry
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Netopia 3347
Netopia 3347 has 4 lights on it,pwr,dsl,lan internet.
Internet light should be off on the CPE and u need to disable DHCP in the Netopia as well to communicate with Sonicwall.
Jun 08, 2008 | Computers & Internet
Got a 3347 modem from Netopia and ATT/sbc. We have a sonicwall tz170. We have bridged the netopia, but We cannot get out to the internet. We cannot take the sonicwall out of the loop, because the HP...
Hello sir,
I didn't necessarily need to enable QoS when I was on 3 meg, but now that I've downgraded back to 1.5 once again due to financial strain (and since I'm not at home that much anymore), it's critical that I find a way to properly enable QoS. Why? My sister is here on the weekends, and so am I. An example of the connection stress I have to go through is when she's streaming a video from Stage6 or Veoh, I have to undergo lag whether I'm viewing a web page or watching a Youtube video. Sometimes, the lag is ridiculous...and for those who think my DSL is at fault, check out the stats:
ADSL Line State: Up
ADSL Startup Attempts: 1
ADSL Modulation: ADSL2+
ADSL Data Path: Interleave
Datapump Version: DSP 5.2.2.0, HAL 5.2.2.0
Downstream Upstream
SNR Margin: 19.00 26.00 dB
Line Attenuation: 58.50 39.00 dB
Output Power: 20.97 11.83 dB
Errored Seconds: 0 0
Loss of Signal: 0 0
Loss of Frame: 0 0
CRC Errors: 0 0
Data Rate: 1493 249
(On a fast path profile too, mind you; it is not interleaved according to the 11 ms 2nd hop on a tracert)
Anyway, back on QoS, if I could just find a way to limit the bandwidth to my sisters computer or to make my connection the higher priority of the two, I would be fine with just that, because sometimes, I can't even break past 30 kb/sec with her hogging the connection. The question is, how do I go about doing it? emotionless.gif
Hmm..
Anyway...I'm really at a loss here, and I'm assuming this is the screen where I can add QoS profiles. Upon clicking add (or edit), I am transferred to this screen..
This is how I've attempted to setup a QoS profile to prioritize my connection (the inside, network IP address typed above). I'm not sure if it will work or not and I will have no idea until my sister comes over here this weekend. The point is, I just want to be ready and not have to reconfigure and reboot my modem constantly to set up QoS properly.
If anyone, and I mean ANYONE could offer me some insight on properly configuring my router to properly prioritize my connection over hers (even if it's just port 80; I don't care), I would much appreciate it.
I apologize for the rather...lengthy post.
Good Luck
Don't forget to rate the solution
Mar 11, 2008 | Computers & Internet
How to configure Sonicwall TZ 190? I have connected console to the Sonicwall and trying to open it via Console. But no configuration or prompt is coming. Kindly help ASAP.
open control panel and then add printers and other hardware, then up in left hand menu go to system then hardware, device managed and check if your driver is updated. if it says it's working properly then uninstall it and it'll pop back up reinstall then it should work fine.
Dec 03, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
Sonicwall vpn configuration
Need more info,
" I want to configure two VPN for different customers but both at the same host computer."
You can havemultiple VPN`s, and port forward to anyewhere on the inside or dmz.
Need to know what you are trying to achieve.
madmac
Dec 01, 2007 | SonicWALL TZ170 (01-ssc-5740) Firewall
Site to Site VPN Link with dynamic dns
Hi Rajmeet, Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions. http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
Apr 02, 2007 | Sonicwall TZ 170 NFR (01-ssc-5564)...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
636 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
