Question about Kodak EasyShare Z700 Digital Camera
Kodak Z700 Camer appears to be in a locked out mode. The lens is stuck partway out and does not retract if the camera is turned off. When turned back on The Green light comes on for approximately 5 seconds and then goes off. The viewing screen comes on for 2 to 3 seconds and goes out as well.
  • srjmkj Jan 27, 2009
    camera lens wont come out, green light stays on when I turn camera off
Tentative solution:
I had the identical problem. I went as far as disassembling the camera ... not recommended.
Instead of fussing with the lens cover, I pressed on the lens assembly (gently), the lens retracted and the lens cover closed.
My camera works now. It will be my last Kodak.
Good Luck,
Mike
Posted on Dec 16, 2008
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Lens is stuck
Time for a new camera, the cost of repair is way beyond value of this camera.
Jul 01, 2009 | Kodak EasyShare M863 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
Try helping the camera to retract using your fingers while you turn camera off, try also helping lens to full extent if they don't.if you do not succeed in this simple way the camera lens must be taken apart and reassembled at a repair shop.
Jul 25, 2008 | Kodak EasyShare M853 Digital Camera
Lens problem
I have had the same problem with a different camera, the problem started when I did not have sufficient battery charge to turn the camera off completely. The camera shut down, but the lense did not retract.
You can try a few things:
First try remove the batteries and holding the power button as if you are going to start the camera, then reinsert and try again. (make sure they are fully charged first)
You can try connecting the camer to the computer before you turn it on. Connected to the computer the camer goes through a slightly different start up procedure.
Try switching it to playback mode on restart.
If these fail I have a couple of tricks up my sleeve, but need to know the answer to these questions:
1. has it suffered water damage?
2. has it been dropped recently?
3. what happend when the lense did not close properly? Is this the first time?
4. Can you access the menus when "restart camera" is on screen?
Just post a comment back
Jun 13, 2008 | Canon PowerShot SD1000 Digital Camera
you have a problem with your lens alignment try to turn it lightly and push it or tap it..
May 15, 2008 | Kodak EasyShare Z700 Digital Camera
Lumix tz3
Low battery maybe? Try holding camera firmly in one hand, with camera on and in record mode, and strike in on its edge firmly on the heal of your other hand. This technique is often sucessful with temporary camer 'quirks' like freezing, lens not fully retracting, etc.
Dec 31, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens Error
the mechanism is wrecked. Kodak will quote a repair price you won't like it much or you could simply buy another camera
Oct 05, 2007 | Kodak EasyShare Z700 Digital Camera
Kodak EasyShare Z700 Digital Camera Logo
255 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
