Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series not agitating
Hi -- my Kenmore 80 no longer agitates. I can hear the something spinning, but it won't engage the agitator. Can you tell me how to fix this? Is it the same fix as in the 70 series?
Thanks very much for your expertise.
  • tso yen Jun 11, 2008
    I have a Model 110 Extra capacity heavy duty Washer.
    Problem: Water fills, not agitating,not spinning, water drains. water fill again for rinsing (manual setting) not agitating or spinning, water drains.
  • kvincent5964 Nov 21, 2008
    My washer fills but does not spin or agitate. It makes sn odd noise instead suring the entire cycle and then drains.
  • 246 Answers
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Posted on Jun 13, 2008
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
I have a sears Kenmore series 80 and the agitator doesn't work very well. It sounds like something is almost broken in the top of the agitator itself. How do I remove the agitator to find the problem.
If the top portion of the agitator (called the "auger") is no longer spinning like it should, you may have worn agitator dogs. The following link explains how to access and replace them:
This is a very simple an inexpensive repair. The part number is included in the link I provided. If this does not correct your problem, or if you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Kenmore 22422 Top Load Washer
The 80 series washer wont agitate or spin. all i
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Jul 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
374 people viewed this question
Sal De
 Brian Main
Brian Main
