Question about Whirlpool Dishwashers
I have a whirpool Quiet Partner III, and the top layer of glasses is not getting clean. I had a technichian out some time ago, and the problrem was caused by food debris trppaed in the filter in the wash module. He saud it was easy to clean that out, so I have removed the lower spray arm, but cannot undo the 4th screw that will allow me to take the grey round filter cover off to remove the food or paper debris. It is under the white flat pipe that delivers water to the wash module, and I cannot work out how to remove that
  • mctp Jun 11, 2008
    The pump is working, as it is only the top layer that is not getting cleaned. The spray arms are not clogged. The question was that there is food debris in beneath the filter, and it is very difficult to take the top off and clean the filter.
    Whirlpool Sucks
I had same problem, would not clean well and fixed it. . I cracked open the door during wash cycle and used screwdriver to defeat the door lockout. The water from the bottom sprayer was only shooting half way to the top of dishwasher. To fix I removed spray bar(reverse thread). Then rotated white upper water feed tube from 12:00 to 1:30, carefully decoupling it from tube that runs up the back of tub. 4 screws later remove and clean screen. Remove one screw, middle left inside well. Then remove cover to food grinder. Clean out and reinstall.
Posted on Aug 19, 2009
  • 868 Answers
CHECK THE SPRAY ARM HOLES,ARE THEY CLOGGED ??IF THERE NOT YOU MAY NEED THE PUMP REPLACED (NO PRESSURE).........BY THE WAY THE POWER DRIVE UNIT IS NOW REFERED TO AS A > MOTOR/PUMP WHICH IS NOT INCLUDING THE PUMP.IT'S THERE WAY OF ADDING CONFUSION WHEN WE ORDER PARTS. 1ST LOOK FOR CLOGGED SPRAY ARMS. LEAVE A RATING !!
Posted on Jun 08, 2008
Whirpool quiet partner 3 gold. panel lights work and say it is wasing but doesn't start
The timing circuit may be defective and the circuit board needs replacing. Have an authorized serviceman do a continuity test on the board and have it rest to factory specs.
Feb 27, 2014 | Dishwashers
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
What is the reset code for a whirpool plus quiet partner III
heated dry and high temp wash and toggle back and forth these 2 keys within 8 seconds till all the lights light up.
Aug 30, 2010 | Dishwashers
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
My Whirpool Quiet Partner III has no power. I
Hello there: It doesn't work at all If your dishwasher doesn't work at all, check these: Door switch Wiring Timer or selector switch Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker. Door switch
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors. Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
May 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Not cleaning properly
Our Whirlpool Quiet Wash plus is 20+ years old and was on its way out the door because of erratic white residue, spotting, and film.  Nothing worked: vinegar, different soaps, more soap, less soap. Today I opened it up and started digging behind covers and checking the insides - multiple places were clogged with a soap/mineral film - ugly! I sprayed the insides with Restore 4 (a tile cleaner) and scraped and brushed and broke loose the hidden deposits. The only thing I didn't open was the sump pump - but now know how to do so. (thanks FixYa) Then I added about a 1/2 quart of vinegar and ran it full hot on the heavy wash cycle, added more vinegar between each cycle and let it dry.  It looks super inside - the gunk is gone.  I am now washing a load of glasses and am hoping for the best!
Feb 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
257 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
