Question about Nikon COOLPIX S200 Digital Camera
Lens error - Nikon COOLPIX S200 Digital Camera
  • 14 more comments
  • x Kaaananeee Jun 18, 2008
    When we try to turn it on, it makes a eghh sound then says "lens error" then, shuts off automatically.
  • Anonymous Jun 19, 2008
    i took my camera to the beach, and apparently got sand in the lens' .
    So everytime I turn it on it makes a urhhhht sound, and focus' on its
    own, how can I fix this?
  • onlykaylaxo Jul 07, 2008
    my Nixon camera is fairly new, and was working fine one moment, I was taking pictures and then after I turned it off, I went to turn it back on and it starting zooming and making the urghtt noice as it focused in and out. it does that several times and then the lens error notice shows up on the screen. then i press power and it turns off, but when i turn it back on, the same thing happpens.
  • jbones314 Jul 13, 2008
    The same thing happened to me. I went to turn my camera on and it did, but the lens kept zooming in and out and then finally stayed in and a message popped up on the LCD screen that said Lens Error with a red exclamation mark. My camera is relatively new and i've never dropped it. I did take it to the beach once or twice, but i didn't get any sand in it.
  • likieJ Jul 16, 2008
    I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
  • simplysavulo Aug 09, 2008
    I turn it on and it makes an extremely weird buzzing noise and the screen shows up white with red words saying lens error with an explanation mark.
    I don't know how to fix the problem.
    I took it to the beach twice and when I came home it stopped working!
    I've tried blowing in the lens and turning it on and off but I have no idea how to fix it!
    Can any one help?
  • nadamame Aug 25, 2008
    Just over this last weekend, I was using my camera to take pictures of my daughter and then all of a sudden the camera lens started going in and out the focus was off and then "lens error" appeared on the display. So I turned it off and then on. The problem is persisting and there is a strange noise too. I did not drop the camera or anything. This happened out of the blue!
  • jksnivas Oct 03, 2008
    am also havin prob wid lens... whr can v solve da prob.. any ideapls drop da address...
  • Anonymous Nov 20, 2008
  • efcraft Dec 03, 2008
    camera turns on, lens extends, screen says lens error!
    camera won't operate any further
  • CK44 Dec 22, 2008
    Same thing with me. less thantwo yearsold. worked fine one day and the next, turned it on and the lens zoomin in and out for awhile then lens error pops up. Jackboy - if you have any knowledge please share. "come on try harder is no a solution and this is all the info thats available." if you have something to offer, great. otherwise don't bother replying.
  • cyi cetiti Dec 26, 2008
    i hope u can help me,,about my camera's problem (Nikon S200), just now, i've just broken my camera..it was fall down, and the lens of the camera couldnt move,and stuck with side position, and when i turn on,, "lens eror!!", how can i fix it? if i bring it to the repairman, how much many i should pay for this? im really sad, please help me...
  • Anonymous Mar 08, 2009
    When we say lens error it means that the camera lens won't go out and the screen says lens error
  • Anonymous Mar 09, 2009
    I had the same problem straight out of the box...where it turns on, lens goes in and out and the says LENS ERROR! I returned it, received another camera and two months later, same thing. There was no reason for it, I have never dropped it or gotten any debris in it. Just a subpar camera I'm afraid. So glad I purchased it from Circuit City that is now out of business! ha! Guess I'll be talking to Nikon directly :(
  • tcrisler172 Mar 14, 2009
    Just tried Jaydeeee's solution....got zapped when I touched the capacitor. I wouldn't suggest removing the back if you don't know what you're doing. I'm going to find a different camera for my daughter. Won't buy a Nikon again.....
  • m_jubara Apr 17, 2009
    lens error on my coolpix s200 camera a dont know what to do pls help me
Ok,i had this problem & couldnt find solution anywhere,so i took the back off the camera to reveal the lense unit.Now there is 2 screws in the middle of the back of the lense you need to remove together with ribbon cable.Underneath this is a small square rubber seal which was not seated properly.All i done was to seat it back in the right place,put all back together & hey presto,turned camera on & all was good.
This might not be the same problem you all have but it worked for me.
Good luck !!!
Posted on Feb 11, 2009
SOMEONE GIVE ME A SOLUTION!!!!
Posted on Oct 19, 2008
I had just turned off my camera cause i was going to use it later to take pictures of my little sister.. when i had turned it back on to take a picture it turned on fine but then the screen turned black and the lens just kept going in and out. so i turned it on and back off and noticed everything was blurry on my screen then it would shut off again and it was making some buzzing noise i dont understand how this could happen i had my phone with me the whole entire time.help!
Posted on Sep 28, 2008
    Genius:
  • 2,985 Answers
What lens error - more detail come on try harder
Posted on Jun 08, 2008
3 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Apr 14, 2010
  • 1170 Answers
SOURCE: Nikon S220. Lens error. turns on but displays lens
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 31, 2010
Lens error
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Keep us updated.
Jun 03, 2011 | Nikon COOLPIX S200 Digital Camera
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
BATTERY is fine, but lens barel will not extend and lens open when I hit the open button
Problem with the lens stuck; is common defective that need new lens unit replacement or just repairable.
Keep us updated.
May 31, 2011 | Cameras
Lens error, restart camera error comes up and lens
not able to get opendand the sensors of the lens unit not able to conform the position of the lens,is due to the damage of the gears/mechanism of the lens fuction,so get it serviced/replace lens unit
Mar 03, 2010 | Canon PowerShot A480 Digital Camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 14, 2009 | Canon Cameras
"Lens error, restart camera." The lens won't close,
Jun 04, 2009 | Canon PowerShot A560 Digital Camera
Lens error= restart camera - this is the message I am receiveing from my cannon SX110 IS
May 24, 2009 | Canon PowerShot SX110 IS Digital Camera
Lens error
May 17, 2009 | Canon IXY 1000 Digital Camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Nikon COOLPIX S200 Digital Camera Logo
644 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
