Question about Kitchen Ranges
We have a new maytag kitchen stove model merh865raw. We have had it about 2 weeks. Now the surface indicator light will not light up when in use.
  • 1 more comment
  • woodwork594 Jun 10, 2008
    Just to clarify, we are referring to the element indicator lights (page
    9 of manual No 3) none of the four lights work!!! All the elements
    work- I am very upset with this new stove - need help- THE WIFE
  • Anonymous Mar 09, 2009
    stove burners are turning brown after use
  • Richard
    Richard May 11, 2010
    If the indicator light you are referring to is the 'surface hot' light then either the element has failed or a connection to the element has fallen off.
    If the indicator light you are referring to is the 'element on' light
    then either the corresponding control switch has failed or a connection to the switch has
    fallen off.
    It may be possible the lamp has failed..although never have seen one fail yet.
  • 413 Answers
If the indicator light you are referring to is the 'element on' light then either the corresponding control switch has failed or a connection to the switch has fallen off.
Posted on Jun 08, 2008
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
Elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
May 20, 2010 | Maytag PER5710 Performa Electric Kitchen...
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Having trouble cleaning splatters off Ingis Glass Top Stove.
Use DeBruce Polish- a true multi-surface cleaner. There is a transfer of particulates from pan to glass surface aided by the heat. The cleaner will remove this "staining". Also use on stainless steel rubbing with the grain- this is the one product that truely cleans the surface. Follow up with baby oil or a stainless steel "polish that is oil based to "seal"the surface.
debrucepolish.com
Jan 13, 2009 | Maytag MER5730 Electric Kitchen Range
The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Oct 22, 2008 | Frigidaire FEF366EC 30" Freestanding...
Maytag stove MGS5770ADB - Burners will not light - ignators
The spark module should be behind the rear panel of the range, or behind the bottom drawer, mounted on the interior back wall. If you go to searspartsdirect.com, the part is listed as item number 22 under the "Gas Controls" heading. The part number is 74004283. Just type in your model number and follow the links on the next page. There are helpful drawings to assist you. If in doubt, trace the wires from the the surface igniters and they all will lead back to the spark module. I hope this information helps you. Let me know if you need further assistance.
Jun 21, 2008 | Maytag MGS5770 Gas Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Hot Surface Light Indicator on Model MER6770AAW
just give your model number to a parts dealer and part name(hot temp sensor) and he will set you up
Dec 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
191 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
