Question about Hussmann Freezers
Defrost tube needs replacing
Hussmann Freezer Model LF 12 serial no 8002-5502
The defrost tube is 230 volts 12 amps
  • 828 Answers
12999 St. Charles Rock Road
Bridgeton, MO,
63044-2483
USA
Phone: 314.291.2000
FAX: 314.298.4756
Posted on Jun 10, 2008
What the best way in defrosting evaporator when full of ice
http://www.hussmann.com/Installation%20Manuals/DCCG_DCSG_06_im.pdf See page # 6
Oct 20, 2010 | Hussmann Commercial Freezer DCCG-12
What the fastest way in defrosting dairy cooler
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Freezers
Freezer is on and just stopped working
Aug 16, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Defrost circut wired hot nuetral ,should this be d/c with a transformer
Probably uses a Paragon 8145 timer. Wiring as follows
L1 to 1/2 on timer, L2 to 2 on timer, Defrost Heater to 3 on timer,
Compressor to 4 on timer, Klixon to X on timer
May 22, 2009 | Hussmann Commercial Freezer DCCG-8
I have a True Freezer Model T-49. It works fine but every 3 or 4
This sounds like a stuck relay to me. I have seen this problem before. The defrost clock kills power to the compressor relay coil during defrost. If the contacts in the relay are welded together the compressor runs while unit is trying to defrost. On newer units this relay is mounted in base of unit on the side or back of the electrical box near center bottom of unit. The compressor relay is a small rectangular box with 4 wires attached. It can be replaced with a single pole 20 amp contactor with a 120 volt coil/ or 240 volt. Check the units name plate voltage rating and ratings on old relay! ;)
Mar 14, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Need defrost unit
Call Hussmann Corp at the number I posted. Give them the model number and serial number and they should help you out. There is also a fax number if you wish to use a fax.
Jun 11, 2008 | Freezers
Freezers Logo
104 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
