Question about Akai PDP42Z5TA 42 in. Plasma Television
TV won't turn on
When I turn on the TV the green light goes on and there is a little low light flicking but it will not go into the blue opening Akai screen. could this be a power supply problem or a chip problem?
Thx
Lew
  • whateverabc Jun 11, 2008
    Exactly same as above. T.V. only 5 months old, still waiting on crappy customer service. When you plug the T.V. in light comes on red, press on it goes green, after that a slight flicker on the screen. To turn it back off you have to unplug from the wall. No service codes I found seem to be responsive.
Whateverabc
Just got my tv back finally Oct 7, 08. it turned out it was the MAIN DIGITAL PCB. the part # is: 6771E421D04-01. I was under warranty, but labour,pickup and taxes was 306.88 Canadian$(not charged to me, but charged back to akai). That does not include the price of the part, which you would have to pay if you were not under warranty.
Posted on Oct 08, 2008
Have a akai tv that's has a green or yellow tint
Hello
Check the picture tube base card for any loose solderings. Your TV lacks Blue colour putput. Check all the solder points on this board. Resolder all the susepected solder terminals [especially take care to blue output section], by applying a little more solder. Check the base connection solder terminals of the blue output transistor. It might be loose, or transistor is defective.
Mar 29, 2012 | Akai Televison & Video
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Where can i get power supply board akai lct2016
that does not sound like a power board issue in my travels it aways is the mainboard . try shopjimmy.com or andrews Electronics or Tops Electronics in Haverhill ma
Dec 02, 2009 | Akai LCT2016 20 in. LCD Television
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Mar 14, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Akai PDP42Z5TA 42 in. Plasma Television Logo
197 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
