Question about Gateway MX6920 Notebook
Notebook Fan or Hard Drive Dead
The screen went black, then it powered itself off, and although the indicator lights say it is receiving power (whether through battery or a/c adaptor - I have tried both), turning it on does nothing. I opened up the back panels and tried it again - the fan will attempt to spin but stop immediately.
So is it refusing to start because the fan needs replacing? I'm not getting a hardware failure beep so I'm hoping it isn't the hard drive.
  • HgS0013 Jun 13, 2008
    I tinkered with the fan and got it to work, and it will "start" but tells me there's no OS. So now I know what's going on. Thanks anyway!
  • 33 Answers
When you leave it for a while will it start, If it dose dose the cpu fan work if so then It's not your fan, But if it shuts down after a short time it could be that it is over heating, That could be because the fan is not seated properly or heat sink is blocked
Posted on Jun 12, 2008
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
I have a Toshiba Satellite A105-S101 it was working well then it was left idle for one month then when i tried to update the screen went Blank/black screen, switch is on, no bios set up, no avg out,...
Dead PC
Possibly a RAM issue or errors on the hard drive stopping the display driver from working properly. Remove power sources, remove RAM and hard drive. See if you get a display when the power adapter is reconnected. If you do, remove power source and fit RAM, (if not motherboard may be faulty). Repeat and if still working, remove power, fit Hard Drive and boot again.
Assuming your OS is Windows Based;
Reboot and use safe mode run CHKDSK/F and when finished check the drivers.
Hope that helps.
Feb 04, 2011 | Toshiba Satellite A105 Notebook
Acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Aug 02, 2009 | Acer Aspire 7720 Notebook
Phillips DVR Model DSR704...fan works, black screen, no powing up
the power supply is bad.
I had to same problem with mine after a power outage. Luckily I had a spare TIVO series 2 receiver with an identical power supply. Popped it in the busted TIVO and I am back in business.
Apr 24, 2009 | Philips DSR704
Compaq R3000 laptop screen went black
Give this a try -
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Let me know if it doesnt work.
Jan 20, 2009 | Compaq Presario 2190US Notebook
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Laptop wont turn on philips freevents x51
The most likely problem is that your Hard Drive has Died.
If you can readily access another Laptop HDD, try it and see.
Other than that, I'd say the Motherboard has decieded to give up the Ghost.
Just Remember, A Laptops life expectancy is 3 years, after that you are treading on thin ice keeping Important Documents on it.
Nov 27, 2008 | Computers & Internet
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Gateway MX6920 Notebook Logo
145 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
