Question about Toshiba (K000016310) Cooling Fan
System warning pop-up
Have a Toshiba A15 laptop. Fans and cooling system working. Not overheating but System Warning kepps poping up. Warning a problem with the cooling system has been detected. How can I turn off this pop up.
It's an XP System
  • 2 more comments
  • Tampa Larry Jun 11, 2008
    There are about 50 bios files. I trust your expertise but give me a few steps to find the file to shut off the warning system popup.. Have a cooling pad, nothing is overheating
  • Anonymous Dec 31, 2008
    I have a toshiba laptop showing a warning message:
    "warning: A problem with the cooling system has been detected. Please turn off the computer immediately, and return it for service."
    Can some one help me with this matter?
    Kind regards,
  • juan_solis_m Apr 20, 2009
    I habe a sallite a 25 275 with de same problem. The fan run anthen stop and re run.
  • Jim Whitley Jun 22, 2013
    I bought a A665 in 2010 and had problem with the windows 7 crashing, after two crashes the fans warning started and it began to overheat. Since Toshiba has no support is in Brazil, I took it to the local computer repair tech it worked about a year and the same problem started again . Now the health monitor shows no problem but the "cooling system warning" pops up on start-up. I am really sick of it. I would sell it but I am too considerate. Tie a rock to it and throw it in the Ocean. It is a piece of junk
I bought a A665 in 2010 and had problem with the windows 7 crashing, after two crashes the fans warning started and it began to overheat. Since Toshiba has no support is in Brazil, I took it to the local computer repair tech it worked about a year and the same problem started again . Now the health monitor shows no problem but the "cooling system warning" pops up on start-up. It also began freezing up too. If you turn off the all the eco-junk and power saving, turn off sleep modes set everything to " never" it quit freezing up ( for now anyway). I am really sick of it. I would sell it but I am too considerate. Tie a rock to it and throw it in the Ocean. It is a piece of junk.
Posted on Jun 22, 2013
  • 95 Answers
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Posted on Jun 09, 2008
Cooling system
If you can buy the pressurized air and blow through the vents of remove keyboard to expose cooling fan a blow with air to remove dust particles
Jan 20, 2014 | Toshiba Computers & Internet
Toshiba A205 laptop charges fine, but freezes when adapter is plugged in.
Identification
  • Computer shops say that up to 20 percent of Toshiba laptops brought in for repair have issues with overheating. Symptoms may be as simple as the keyboard and bottom of the laptop being very hot while the computer is working, or the fans running at maximum rotation while the system becomes very slow for several minutes at a time. More inconvenient issues are common, such as the system completely seizing up and having to be "killed" with the battery pulled out, or the computer may shut down all by itself with no warning. Sometimes the laptop works fine until the user starts any significant memory-demanding applications, like photo editing software, several Internet windows being open at the same time, or an Internet video stream.
Significance
  • A common problem with the Toshiba laptop is that dust becomes clogged between the cooling fan and the heatsink, a device which lowers the temperature by dissipating heat into the surrounding air. Now heat produced by the processor is trapped inside the laptop, and the fan cannot blow it out.
Jan 10, 2013 | Computers & Internet
My car said "engine hot
Full coolant level does not mean your engine cannot overheat. You need to fix the problem as overheating will destroy the engine if not addressed.
The radiator cooling fans must be working, as must the water pump. The thermostat must also be working properly.
There must also be no air in the cooling system as air locks will impair water flow. When cooling systems are drained fully or partially and re-filled air in the system must be bled out using the correct bleeding procedure for the particular engine/cooling system. Failure to do this properly will lead to overheating.
If you ONLY see the overheating warning when running your aircon you need to check that the electric radaitor fans are kicking in at idle when you switch on and run the aircon and the engine has been warmed up some. If they do not start operating when the a/c is running you will get an overheating condition in normal driving conditions.
If the radiator fans are operating normally and you still get an overheating warning when the aircon is on or off the most likely culprit is a faulty thermostat in the engine's cooling system which will need to be replaced.
If you have either a faulty thermostat or if the water pump in the cooling system fails you will get continuous overheating whether the aircon is on or off.
Sep 05, 2011 | 2006 Chevrolet Impala
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
My Toshiba is having cooling system issues, the laptop makes noise when the fan is on, and it stops and starts arbitrarily. The system becomes terribly slow and shows a popup saying "cooling system...
Hi, you can try to clean fan with a compressed air can, if the fan works most of the time this helps and you will not need to take anything apart, just pick up one at your local electronic store, follow the safety instruction on the can and spray all the air ways starting with the openning under your fan, but start SLOW and gradually increase the air flow and be very careful not to let the air pressure break the fan fins by sudden changes in the air flow... As for the pop-up it may not nessesarly mean it is heating problem, it may be a virus and you may want to install and anti virus just in case... Best od Luck
Jan 17, 2011 | Toshiba Satellite A15-S1292 A15-S157...
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
Cooling Fans compatible with Toshiba A15 laptop
You can't replace the fan, you have to replace the power supply. In order to find out whih one you need the best thing to do is open your PC and find out the Wattage. It will be marked on the outside of your power supply. Just in case you do not know where the power supply is, if yo see where the vents are on your computer the power supply is there. It has a fan to blow the hot air out of it..
Don't forget to rate this solution with four stars before you log out.
Jan 23, 2009 | Antec TriCool 3.125" LED CPU Cooling Fan -...
Toshiba Satelite M10 cooling system not working
If you DO NOT hear the fan running, have it looked at by a professional. Your fan may have died. If you can hear the fan running, blow out the fan exhaust port in the opposite direction of normal air flow. Especially on lap tops, the heat sink cooling fins become completely clogged with dust. When this happens the processor overheats causing it to run slow and eventually shuts itself down to keep from going super nova. You should blow it out at least once or twice a year. Also, if you use your laptop on the couch or in bed, place it on a hard surface like a cutting board or something similar that will allow air to flow underneath the computer. This will also help prevent dust from the cushions or blankets and such from clogging the cooling fins on the heat sink faster than usual. Remember blow it out in the opposite direction of normal air flow. You want to blow the dust out the same passage it came in through.
Sep 15, 2008 | Toshiba Computers & Internet
Cooling Warning Setting pop-up
Check Toshiba.com for an upgrade on the thermostat.
Does it feel too hot to you yet?
Jun 11, 2008 | Toshiba Satellite A15-S127 Notebook
Toshiba satellite p10-832 shutting down
Go to the following link... Best
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlView.jsp?soid=1931079&BV_SessionID=@@@@0393765923.1216012797@@@@&BV_EngineID=ccchadeeilhefeecgfkceghdgngdgmm.0
Nov 18, 2007 | Computers & Internet
Toshiba (K000016310) Cooling Fan Logo
2,964 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
