Power is there checked it we overrode everything to see if we could get the compresser to work
Fan turns on but not by its self...the compresser still will not turn on...please help
    Scholar:
  • 54 Answers
Ok You need to find out if the compressor is getting the power it needs to run. It's a little tough to get to and if you slip you can get a really nasty shock so be super safe and careful.. Turn the 220v supply voltage off to the condenser, remove the service panel from the unit. Find the compressor and remove the compressor terminal access cover. There's a red black and yellow wire and/or the terminals are labeled either inside the compressor terminal cover or by the terminals: (R)-Run-Red wire, (S)-Start-Yellow, (C)-Com-Black wire.
You need to set your volt meter in the 220vAC Rng and remove the red wire from the (R) terminal and connect it to the red lead of your meter then remove the black wire from the (C) terminal and connect it to the other meter lead being careful that neither connector can touch any metal parts when the circuit is energized. Turn power on to the unit if your meter shows 210 -230v Then your compressor is bad or of on internal overload.
Internal overload can sometimes take an hour or so to cool off and reset. Turn the power off to the unit and check for continuity between each compressor terminal. If you have continuity then check from (R) to Grnd. If theres is continuity between terminals but not to ground then replace any run and start capacitors reconnect wiring and try running the compressor again with an amp meter on the yellow wire so you can see whats happening.
If your not getting 220v then backtrack, Check the wireing harness to the compressor the relay and so on till you find the 220v your compressor is looking for :) GL Hope this was somewhat helpful.
Posted on Jun 09, 2008
  • Wes Rackley Jun 09, 2008
    This is a new unit and you said the fan runs but not by it self?
    Do you mean that when you turn the fan by hand it starts spinning you probably do not have the required 220v line voltage to the unit.
    It sounds like you may have an improperly wired installation and could be a potentially dangerous situation you need to get a qualified technician on location to help you straighten this out. GL!
Having problems with my bryant 601a package unit blower is working and moving air but not cold my unit fan is turning off and on but not sure the compresser is working i replaced the capacitor any other...
I would check to make sure the compressor is in fact working (people sometimes mistake the condenser fan being on for the compressor, which makes an almost dieseling sound). The indoor fan is a separate circuit from the compressor.
Aug 26, 2013 | Bryant Heating & Cooling
Dalkin VRV system air conditioner not cooling
Most the time when unit does not get cold,but air is still attempting to blow air, it is because it needs to be cleaned. Sometimes filter or vents are dirty. Try and use a can of compressed air and blow it out real good, next step is check the thermostat to see if you hear a click sound when turning it to a certain temp. If not, it can be the switch it self or the relay that triggers it. If you can give me a few more details of what it is doing or not, maybe I can get down to the root. In other words, you say it does not get cool. But, does it blow air>? fans turning? fuses ok? right source of power to it (amps?) mike
Nov 29, 2011 | Cfm Daikin R410a Split System Air...
My condenser fan is not turning on my Maytag portable. Everything else is working find but it is not exhausting anything. Is there a reset?
need to check the motor for power if power to the fan than either something blocking [clear ]===the motor bearings are seized [try to oil the bearings to free it up ] sometimes catch in time and will run===or the windings are open[burnt up motor need to replace]----if no power to fan need to check wiring -relay and or switch
Jul 23, 2010 | Maytag Portable Air Conditioner M6P09S2A
My air condition is working but the fan is not turnig
fan has to turn for system to function properly turn off breaker see if fan turns if not bearings are shot if it does maybe fan motor bad or wiring issue! Good Luck!!!
Jun 24, 2009 | Goodman CKL36AR36 Air Conditioner
Everything turns on for my refrigerated unit, but no air blows.
I would have to guess that the fan is not working, which could mean that the fan is bad, or that there is a bad fuse. Also, it could be in the control panel that turns on the fan. If you know anything about wiring. Try hard wiring the fan and see if it actually works. If it does, then you would move on to checking the control panel.
May 26, 2009 | Goodman Heating & Cooling
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
MY AIR CONDITION ONLY PUT OUT WARM AIR EVERYTHING SEEMS TO BE OK FILTER TURNS ON OK BUT THE OUTSIDE UNIT HUMS BUT DOES NOT FAN
Sounds like a bad start run capacitor. The exhaust fan motor may be bad too. Be careful, this unit delivers 220volts of electricity.
Jun 17, 2008 | Goodman Heating & Cooling
Compresser
May be this tripping your compressor,please check the continuity of the following..
1) Continuity of Compressor if this a loose compression
2) Continuity of Capacitor if this a low capacitance or not functioning.
3) Check the power voltage.
Go to the nearest shop for repair the units,thanks
Regards,
Edgz
Feb 16, 2008 | Heating & Cooling
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
