Problem for Electric Fans
Generic problem for all Electric Fans
Wiring new light over kitchen sink
We bought a light fixture at Lowe's on the clearance table, the instructions are missing. How do I know which lead is hot and which is not?
Solution #1
posted on Jun 11, 2008
Rank: Wiz
Rating: 83%, 88 votes
Typically, the white wire is neutral. ANY non-white wire [except green] is hot. Green is typically ground.
Hot wire should go first to a switch or safety device [fuse or circuit breaker]. If this is an unswitched light fixture, the wires will go directly to the bulb sockets. Follow the color codes I just described.
Another solution is to get a continuity tester or ohm meter. The hot lead should show connection to the center contact in any socket.
Popular Solutions for Electric Fans
Hunter Fan Company 5/1/1 Programmable Thermostat
1 Solution
Hunter 52" Ceiling Fan With Light And Remote Control
1 Solution
Questions and Unsolved Problems for Electric Fans
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is...
(More)
I am trying to decide whether to purchase Fanimation Belleria FP4320 with finish that is discontinued Aged Copper. When I asked the vendor via email if it had option for light kit, they said "no". I thought this model FP4320 had option for light kit even if this particular vendor did not sell. I cannot buy if I cannot attach a light kit that is available from another vendor for this model. Can anyone confirm this?
Also what is recommendation for this model.
my hunter fan remote control is not working
give me the color to put in the fan switch number for a fan
how do i wire up a hvk 150a1 fan.i have two black wires coming from the fan but three wires on the...
(More)
how do i wire up a hvk 150a1 fan.i have two black wires coming from the fan but three wires on the socket lead.which wires do i connect together please.many thanks
Broan HS90-B humidity sensing bathroom fan. Unit quit working. Bought new control assembly from...
(More)
Broan HS90-B humidity sensing bathroom fan. Unit quit working. Bought new control assembly from Broan. Motor not hooked up. Unit does not swith on with humidity rise. When cycling on, off, on for manual mode, breaker trips. Mortor not hooked up. control assembly is only thing on circuit.
