Question about Ruud Central System Air Conditioner
Ruud central air system
The water is not drainig out of my system but instead is dripping down through the ducting onto the filter. How do I fix it? Thanx
  • Anonymous Jun 22, 2008
    Defective pan on the coil
  • 40 Answers
Install a condensate pump if you don't have one. Check to make sure it works if you have one and clean it out.
Posted on Jul 03, 2008
Where is the filter on my Central Cooling Air Conditioner York LR49182C (Serial no. EFFS160427) (Model no. M/HD036SC) ?
Your furnace filter or A/C filter is located next to the floor in your cold air return into the furnace. Your other problem is your condensate line out of the A/C box that sits on top of your furnace is plugged. Replace your filter in the cold air duct, and remove your condensate line from the A/C box and blow air in the line to remove the clog in the line.
Jul 20, 2015 | Heating & Cooling
Why would unit be leaking water on the inside unit
If it is leaking on the inside (coil) it usually is a sign the condensate drain is plugged causing overflow, or the coil is freezing up inside and when its off it thaws the ice and melts down the center of the coil and onto the floor,
Jul 21, 2014 | Ruud Central System Air Conditioner
Sweating duct work and pipes
high humidity will cause sweating on cold lineset and ductwork,,, insulate both and it will solve problem
Jun 03, 2014 | Ruud Central System Air Conditioner
Freezing pipes and water dripping on to motherboard of the heater in a Ruud UAKA-030JAZ system. Help?
More than likely, the system is low on refrigerant and the copper line-set is freezing up and water is dripping onto the board in the furnace (and other things) because it is an upflow system with the evaporator coil on top. Other things to check would be:
1. Dirty/clogged filters in the return air system.
2. Fan motor not working inside furnace. (The Blower)
3. Coil dirty/clogged which could be checked by the amount of airflow coming out of the vents. This would have to be cleaned by a technician.
Most of the time, it is the charge which also means there is a leak in the refrigerant system somewhere and needs to be fixed. Hope this helps you out! Good luck.
Jun 19, 2012 | Ruud UAKA030 Air Conditioner
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
The front ac unit has very poor cooling and left running, freezes up and drips water out of the ceiling grill. I s the unit shot?
Ensure the air filter and evaporator coils are clean. If they are clean and everything is running properly, then the unit may need refrigerant. It depends on the age of your equipment and the location of the leak (price to repair) as to whether or not the unit is shot. Check your air filter and evaporator coil first. :-)
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
Water is leaking from under glove compartment
water dripping from under the glove box area is usally a sign of water in the heating ducts. water runs down the windshield and goes under the cowel, then instead of draining, it some how enters the air intake for your heating system. Take off your wipers, and remove your cowel, you will be able to see the air intake (on the passangers side) and the reason why the water is being directed into it.
Sep 28, 2009 | 2005 Dodge Caravan
Locating Ruud Central Air drain pan?? Water has started dripping through the ceiling from the Ruud Central Air Unit...can't find drain pan?
the drain pan is physically inside the indoor unit.
grab a 1/4" nutdriver and open the bottom service panel your coil and drain pan is there, you won't be able to remove the coil properly but you could see if the system is overflowing causing your flooding problem, let me know what you find
Jun 22, 2009 | Heating & Cooling
Too much water condensation
Check your condensate drain. It could be plugged. Or perhaps you have a crack in the drain pan.
Jun 21, 2009 | Ruud UAKA037 Air Conditioner
A/c unit leaking underneath onto floor, puddle in the hall!
from the evaporator coil, the drain maybe clog. clean the unit to fix it.
Jun 11, 2009 | Ruud Central System Air Conditioner
Ruud Central System Air Conditioner Logo
87 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
