Question about Kenmore Oasis HE 27082 Top Load Washer
Noise sounds like loose change or screws.
I have the Kenmore Elite Oasis HE. One year old, just last two loads ago noise started. It sounds like below basket, towards front and or front right. This noise happens when water is changing, not necessarily during cycle ****. It went on quick was for 14 minutes before noise started. I checked carefully, nothing is stuck or any where inside the basket.
Thank you for your help.
  • 246 Answers
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Posted on Jun 15, 2008
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Kenmore elite 110.2706 unbalanced load problems
I have the same problem with my washer though it is a Maytag. the part that grips the drum to spin it is stripping, (and not properly grabbing). Repair man said to just get a new but I'm sure if you find a dedicated enough repairman he may be able to replace that part. The repairman said to replace mine because it was over 8 years old.
Sep 08, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
When my washer is on the spin cycle it goes out of balence shuts down no matter wht size load or how i arange the load never completes the spin cycle this is a kenmore elite oasis 5 years old. #2 problem...
as for the washer there maybe a broken spring or where the spring attaches that balances the drum. look for this firest. for the dryer is it spinning around at the right speed if it is then the belt is ok. is it hot inside the dryer after running it when you open the door. if ti is check the dryer vent hose and exterior door at end of hose to see it they are plugged up . if the hose is plugged up the heat and moisture can't excape and the clothes will take a long time to dry.
Sep 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
What is F54 on the Kenmore Elite top load washer? Less than 3 years old
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel. Good luck
Nov 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis elite He, I am unable to get the washer into the manual diagnostic test mode. A couple of days ago, when I first started trying to figure out the f-51 error code, I was able to enter manual...
F51 is a RPS sensor code .The computer thinks the motor is drawing excessive current to rotate the basket. In repairing these units 8 out of 10 times their was no part failure, the problem was clothing got under the basket causing excess draw.Try taking your hand and spinning the basket it should rotate very smoothly and not have any dragging,if it hangs up at all you can easily remove the basket and get out the clothing that got in there.....
Sep 16, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite oasis he has a rattle inside when starts to spin and when it slows down. sounds like loose change but i cant see how the money could get between the inner walls. unit is 2 years old.
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
How to remove the agitator & the basket on a kenmore elite oasis
See the following Whirlpool Service Manual for their Cabrio washer. It's the same machine as the Kenmore Oasis,
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
May 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
316 people viewed this question
Sal De
fordexpert
Robert Rankin
