Question about Kenmore Oasis HE 27082 Top Load Washer
Change or Screws making noise?
My machines are just a year old. Now it sounds like there is money down in their or screws bouncing around. Only makes this noise when water is changing cycles. Anyone have any ideas?
  • donndoris Jun 09, 2008
    I also have coin clanging in my OASIS. I took the stainless steel tub out and found clothing and coin in the back of the clear plastic basket that was plugging the drain area. I took off the drain filter and found a coin blocking one of the two outlets. I believe coin gets into the pump, mine has a leak. I am ordering a new drain pump to replace it, I will probably find more coin stuck in the pump.....
  • Anonymous Jun 29, 2008
    How do i open the top? No green tabs
  • 246 Answers
If you want to check for coins, debris, etc you first need to open the top of the machine (not just the lid) There are 2 clips in the sema between the front and the top panels (they are green when you shine a flashlight on them) Push the clip towards the rear and lift repeat with the other side. Now there is a peice of plastic on the top (tub ring) Push down while pulling the clips free. Finnally, remove the plastic cap in the center of the basket. There is a bolt underneath that holds the basket down. Once you remove it, lift the basket out. The other alternative is taking the rear panel off. There are two pumps on both the lower right and lower left hand corners. Once you drain the water out, you can check for foirgn objects in there as well.
Posted on Jun 15, 2008
Apart from the cover at the base. How do I access the internals of the machine. I have a loud noise on spin plus I seem to have a water leak inside
The front panel comes off. 1st you need to remove the Facia to access the 3 screws...Leak could be door boot seal noise sounds like drum bearings/ if its under 5 years old phone Hotpoint it will cost around £100 for call, parts are free.....If over 5 yaers think new machine as its quite expensive to do full job and not always worth it if old........
Dec 03, 2010 | Hotpoint Aquarius WF215 Front Load Washer
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
When the drum gros around, it sounds as if a coin
Hi The noise you are hearing is coming from the baffles inside the drum. These are attatched to the drum with screws from the outside of the drum. Something as gotten inside these baffles and causing the moise.
Remove the front ot top panel (Depending on what model) and take the screws out so the baffle releases.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Dryers
I have a whirlpool duet washer that is making very
It sounds like basket support failure. How old is the machine? They usually **** at around 5 to 6 years. Unless you are going to fix it yourself or it's under extended warranty, junk it.
The repair requires a complete teardown of the washer. two to six hours labor depending on tech skill level.
Jun 12, 2009 | Whirlpool GHW9200L Front Load Washer
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Noisey dryer
Peace bumbabob,
Huuum t your service!
1-it may be the belt squealing or high pitched noises telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on! I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunately, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU
Sep 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing machine
Peace Friend,
ngfam1 At your service!
1-it may be the belt squealing or high pitched nosies telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on!I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
Unfortunely, another point to consider!!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Noise sounds like loose change or screws.
You probably have something in your pump. Remove the lower front panel (3 #20 torx bit screws) In the bottom, middle there will be a large white pump. I usually remove the screw holding it in so I can get the edge of a bucket underneath it. Once you rotate the knob in the centercounter-clockwise and the water drains out, remove any forign objects.
Jun 08, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Agitator is making noise
bearings in the transmission are going out. they are fairly cheap if you can change them yourself.
Mar 29, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
