Question about RCA P52926 52" Rear Projection Television
RCA Model #P52754AT Problem
Power button when depressed only lights long enough for television to make slight noise(an internal power noise squeel like HV start ,then power cuts off). I dont know if I have a power supply problem or worse. Tv is old and if too expensive,it's probably not worth much of an investment. I did notice when TV is plugged in i can hear the outlet snap slightly like you would see when you un-plug a device under a load. If you could give me an idea of common problems of this type of TV. Up to this point,this is the first problem we have ever had with this set. Thanks in advance for any help or advise you can give me.
  • verne carey Jun 13, 2008
    TV squeals when turned on, picture a little fuzzy, then roll, then go to lines with no picture. Quite noisy from the audio with lots of static and squealing. Any suggestions as to cause and how to fix it?
    Verne Carey
    Windom MN
    507 831 5112
  • Anonymous Jun 30, 2008
    when i turn tv on the when i started to have the problem the tv when turned on it started to have i line in the bottom of the tv and the noise was like a clicking noise it started out slow then got faster and then it shut off i tried to turn it back on and it just makes a clicking noise
  • RCA Master
  • 8,617 Answers
When that model squeals its usually related to the horizontal output transistor or the flyback.
Posted on Jun 08, 2008
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
53" rca model p52754at
CRT pictures that "bow-in" on the edges usually indicates that the high voltage power supply is failing.
Dec 03, 2010 | Televison & Video
I try to start the tv and all I hear is a slight squeeling noise, think it is the color wheel. I just bought a new lamp. the tv makes the noise it initially makes telling me it is trying to start but two...
If you hear a squeeling noise, then that would be your color wheel. When you replaced the lamp, did you reset the lamp hours? Did you check the power from ballast with a voltmeter to see if you are getting power to the lamp?
Feb 06, 2010 | Samsung Remote Control
It sounds like your high voltage block is arcing and causing the TV to go into protection shutdown temporarily. If that's the case, you'll most likely need to replace that HVB.
The other thing it could be if you're hearing "popping" (snapping ?), is that one of the CRTs could be arcing to ground, maybe the green one since you're getting too much green.
Good luck.
Nov 28, 2009 | RCA P52771AT 52" Rear Projection...
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
Aug 20, 2009 | RCA TruFlat 27F520T 27" TV
RCA P52754AT Two lights went out exact same time,
most likely its the HV splitter which distributes the HV to each of the three CRTs. ( Tubes) They can short out and can cause that symptom
Jun 11, 2009 | Televison & Video
52" RCA Projection TV P52754AT
I'm sorry to report to you all there are so many things, boards&circuits in your TV that can cause this concern.
The first thing I would and will recommend is that you unplug the TV's power cord from it's source, wall, power strip, surge protecter for at least 5 minutes.
If that doesn't correct 'it', thenI would recommend calling an authorized service dealer to repair your TV. This Tv is too complex for the average person to attempt to repair. I hope I helped.
Jun 03, 2008 | RCA P52926 52" Rear Projection Television
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
