Question about Pioneer Car Audio & Video
Trying to put in a sterio in a bmw325i
Can any one tell me the wiering code
1995 BMW 325 Stereo Wiring Constant 12V+ Red/White Switched 12V+ Purple/White Ground Brown Illumination n/a Dimmer n/a Antenna Trigger White Antenna Rear Window, Diversity Front Speakers 5 1/4" Kick Panels Left Front (+) Yellow/Red Left Front (-) Brown/Orange Right Front (+) Black/Red Right Front (-) Brown/Orange Rear Speakers 4" Rear Deck Left Rear (+) Yellow/Black Left Rear (-) Black/Orange Right Rear (+) Blue/Black Right Rear (-) Brown/Orange
Posted on Jun 10, 2008
It won't power on, the security light works when face plate is off
HI.. YOU MAY HAVE LEFT ONE OF THE POWER WIER UNPOWERD THESE STERIOS HAVE TWO .
Mar 30, 2014 | Kenwood KDC-MP2035 CD Player
No sound
Make sure the wiring is proper.. Are all you wiring a brand new player into your car? If yes here's the wiring procedure..
all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Yellow is your constant wire
Red is your accessory wire
Bllack is ground after that there will be a orange wir e that is optional hook up to run the sterio with the dash dimmer 2-3 blue wires which you can use for AMP remote wire or elctronic Antena
then there are the White and white with black stripe
Green and green with black strip
Purple " "
Grey " "
are your 2 front and 2 rear speakers
which go where i always for get but when your installing the sterio you can set the sterio to run frount let and then hook the wiers for that speaker up when you fin the right one
Apr 12, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
My sterio is locked out please tell how to unlock
need to notify a dealer the [ loc ] code is part of security system if u have manual it will advise how to get radio id number which will also be needed or call dealer and will advise how to get radio id number
Mar 03, 2010 | 1998 Cadillac DeVille
I dont now how to wier my car audio amplafier to my car sterio. I need a diagram.
you run the RCA wires wich go to the two big plugs usally on the back left side of your stereo, they are usally red and white, run those from your stereo to your amp. the other wire is the remote wire wich is usally blue, run that from the stereo to your amp. thats the only wires you hook up to your stereo if your installing a sub woofer
Nov 17, 2009 | Car Audio & Video
Gauges wont work,horn keeps blowing
you have a crots wier or bar wiers in the wiering to solve this you ned to
track the wiers amd put eletrikel tap arond war it is bar or put the wiers in the rit plas
Sep 12, 2009 | 1996 Dodge Caravan
Bmw 323i reads phone on display. no response.
maybe you have to try blutooth it if that na work maybe its of on the sterio, sometimes you best to see if you can refere back to the manual, if not try find one for that sterio, as someone before you may have put in a dif connect code, and the sterio needs resetting
Jun 05, 2009 | 1997 BMW 328
Need sterio wiring diagram for 1997 1500 gmc p/u ,factory harness
DON'T REMOVE FACTRORY CONNECTORS!!!!!!!!!!!!!! Spend $15 and buy a wiring kit. It plugs right into your vechile wires and the kit tells you what wires are what. Splicing the wires will lead to headaces down the road!!!
Dec 08, 2008 | 1999 GMC Suburban
S40 volvo 2001 radio problem
Same problem with mine, same model etc. If you input code incorrectly 3 times the word 'OFF' appears. Then you need to leave the ignition in the first position with the radio on with the word off appearing for 2 hours. It then asks you for the code again. Ring your volvo dealer and give them your registration plate number. They should have the code on file. They should not charge for this. My problem is that volvo's code that they have stored does not work so i'm waiting for a repair guy to ring me back. Suspect my stereo was 'swapped out' during a service call. Might explain the cd skipping.
Cheers.
Nov 02, 2008 | 2000 Volvo S40
Got a deck...need to install myself
the best way is to buy a wire harness tomatch your cars then all you do is match the colours from the wire harness provided and the one for your car but if you do the wir cutting method then
Purple " "
Grey " "
Feb 22, 2008 | Audiovox MVP300C Complete Mobile Video...
Radio unlock code
Press & hold the 2 & 3 buttons @ the same time for about 10 seconds; a 2 or 3 digit code will appear, write this # down,press & hold the am/fm button for about 10 seconds: another code will appear, write this # down, then call 1-800-537-5140 and enter 202108 followed by the * key, then enter the #'s that you wrote down from your radio followed by the * key. The call will give you a 3 or 4 digit override code. Write this code # down so you have it if you ever need it again. Enter this # into your radio following the instructions in your owners manual. If you get an override code that starts with 0, you drop the 0 when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour button until the first 2 digits of your code come up, then press & hold the minute button until the last 2 digits show. Then press the am/fm button. This should reset your stereo.
if nothing happens you should leave your car running for 1 hour.
Dec 11, 2007 | Car Audio & Video
Car Audio & Video Logo
97 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
