Back to:
Tags:
Quasar VV-2002 20 in. TV/VCR Combo
Large Black rectangle on bottom half of screen
posted by blystone on Jun 08, 2008
When I select a channel the picture is normal for about one second and then a black rectangle appears on the lower half of the screen. The screen is normal when I select Guide or Menu, but reapears when I go to any channel. Please help Don
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 08, 2008
Helpful (85)
Lee2fixit
Rank:Guru Guru
Rating: 89%, 60 votes
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Comment by Lee2fixit, posted on Jul 08, 2008
The set I described was a Quasar VV-2000, so perhaps the reset routine would be the same after all.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Large Black rectangle on bottom half of screen:
I don't want to Accept this solution
Can you Help with these TV Combos problems?
My VCR is "locked" . Ho can I "unlock"...
The TV works great. The VCR  records OK, but on...
Can I hook up a dvd to this tv ?
I cannot find codes for my systemlnk 3 remote to work a...
i really need the codes 4 quasar vh5280 tv/vcr combo......
Loading problems.
Repair Service
Find TV Combo Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
