Epson 1280 wont print
After cleaning the print head it will not print on paper, when running the clean print head it fills little ink tray , it was working fine before cleaning, says that there is enough ink on system monitor
  • 2 more comments
  • tedjr3427 Jun 08, 2008
    hey kevin dont quite know how this works
    what do you mean by printer cartridge head? can this be repaired
  • bankerville Jun 16, 2008
    I have the same problem. I put new ink and, and even the cartridge works and runs, it doesn't print.
    Do you know how to fix this.
    I will appreciate your help.
  • ozonetrash Mar 16, 2009
    I have the same problem. I have went through 5 sets of ink and nothing. It dont print at all.
  • 1,847 Answers
Hi i was tring to chat with you where u getting my messages
Posted on Jun 08, 2008
  • Legin Varghese
    Legin Varghese Jun 08, 2008
    if the ink is full the printer cartridge head is gone bad. you have change the ink.
Epson Photo Stylus 1280 print heads do not work
The problem is the print head, The ink cartrige for this printer is just a little bottle of ink. What really causes problem in it IS THE CLOGGED HEAD. If you have skill to reach thepen of the head (part that touchs the paper) use a quill tip or rag soak on water and clean it. Or go to EPSON SITE AND ORDER A HEAD CLEANNER FLUID TO POUR INSIDE THE HEAD AND CLEAN IT.
Oct 23, 2012 | Epson Stylus Photo 1280 InkJet Printer
THIS IS FOR: "glenncuneo" Epson PictureMate
Hi. I provided you a manual for your printer. Please click here.
Nov 05, 2010 | Office Equipment & Supplies
Does not print
First of all please check the ink level. If it is not finished try followings:
First try to run a cleaning cycle. To do that:
- Load paper in the paper tray. - Access printer utilities. (Right click your printer icon, select printing preferences and click the utility tab to access printer utilities) - Click the nozzle check icon. - Print to check it.
Then click the clean button to clean the print head. - Try it a few times.
İf it doesn't help you can try to run power cleaning cycle. But it uses much ink. There must be enough ink in the cartridge.
Hope this helps.
Apr 24, 2010 | Epson Stylus Pro 4800 InkJet Printer
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
Printing misaligned color blotches, little squares off to the
Are you using genuine inks or compatibles/refills? Have you cleaned / aligned the print heads recently? Does it only happen on the second print? Could be a case of excess ink getting onto the rollers which then get hot and deposit the ink on the next paper coming through.
Also make sure you've selected the correct paper type before printing.
Oct 29, 2009 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280 red ink low light will not go out. Have tried replacing both ink cartridges and have disassembled the unit and cleaned the waste pads. I have tried the reset sequence posted on here but it...
Epson color 777 Printer isn't working, the print light is on, but so is the red error light, ink jets are filled, had that confirmed, plenty of paper, what's the problem?
Jan 16, 2009 | Epson Stylus Photo 1280 InkJet Printer
Black lines on prints
Remove the cartridge.....
using a cotton bud clean the ink nozzle area on the cartridge for excess ink..take extra care not to damage the nozzles
... while at it take a piece of rag and try to clean the..service station area(this is where the cartridge goes to the side of the printer)for ink build ups....try to clean the rubbers that wipe the ink off the head as it runs across ..this is near the service station area clean well
it just requires cleaning..try to use little bit of cleaning solution that is available for that particular model..if not use bit of alcohol but do not use it on the cartridge itself ..make sure the alcohol is properly dried as not to damage the head
do reply if this helped
Nov 11, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson 1280
The ink jet printers have ink absorbing pads to catch and accumulate ink used to clean the printheads. The counter on MB counts number of head cleanings and printer startups (at every start up the heads are cleaned) and at preset number of cleaning alerts the operator that "printer needs maintenance" and sets the red light. You probably need a change ink absorbing pads (or wash them and dry 'em up) and then make a reset the count using printer Service Utility (can be downloaded from the web). To get to the ink absorbing pads is not easy - you need to remove the printer case - I am not familiar with 1280, but I did that on Epson 3000 & 5000 printers. In many cases the pads are actually OK , but the MB reaches the count and flags the pads.
Nov 06, 2008 | Epson Stylus Photo 1280 InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Feb 07, 2008 | Office Equipment & Supplies
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
105 people viewed this question
