Question about AcerPower F1 PC Desktop
Over Heating Problem In Acer Aspire L100
How can I solve the overheating problem in Acer Aspire L100? Can I install any liquid-cooling system in it?
There are two solutions to this problem. First set the fan in the PC Bios to rub at full speed all the time. This was too noisy for me.
Second, If you are running Windows Vista, you can adjust the Maximum Porcessor Utilization. From the Windows Control Panel select the Power Options icon. Then select "Change plan settings" for which ever power plan the PC is set to use. Then select "Change advanced power settings". Expand the "Processor power managment" by clicking on the "+" symbol. Finally click on the "+" for "Maximum processor state". I would try changing this setting to "90 %". This worked fine on my ACER L100 and it no longer overheats.
Posted on Aug 16, 2008
    Problem Solver:
  • 4 Answers
Replace the thermal grease. My fan would always get loud and then my system would shut off. After I replaced the thermal grease, it is quiet and has not shut off unexpectedly.
Posted on Apr 20, 2009
    Sergeant:
  • 243 Answers
No liquid cooling would be to hard to install. you can attach another fan. but you will still have a problem. the downside to these computers is there short of made to overheat. you can attempt to do liquid cooling as others have done. but thats an expensive waste. your best bet is to buy a new case and mother board. for about 80 dollars. swap out all your guts and be happy. youd have everything and not fry your dvd rom and harddrive. as most of these L100's have nice processors and a decent amount of ram.
Posted on Jun 13, 2008
Laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Jul 16, 2010 | Acer Aspire 5535-5050 Notebook
Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
Hi
thank you for your query
Please can you try the following
1) go to www.devicedoctor.com
2) Download and install the device doctor software
3) Once installed open it up and click scan, it will then scan your PC for the best driver
4) Download the driver (entitled VGA driver) and install
5) Restart and see if this cured the issue
Regards
Shauqat
Jun 02, 2010 | Acer Aspire L100 PC Desktop
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Acer l100 shut down
You can buy a Laptop cooling pad for less than $40 from most any computer store.
Oct 26, 2008 | Acer Aspire L100 PC Desktop
L100 overheating
In most of the cases the cooling radiator inside the computer is full of dust, clean it as well as the fanblades and things will improve.
Try to find a place nothing is blocking the inlet on the back and the outlets on top and in the front, open the part which covers the usb and other connections on the front.
Sep 30, 2008 | Acer Aspire L100 PC Desktop
Possible bad motherboard/overheating problem w/ Acer Aspire mini L100
You wont be able to replace the mother board as it is a propriatary Acer unit and is now obsolete.
In all honesty these machines are so poorly designed you would be better to write it off.
The 3 machines i had fail and managed to repair are all now dead again with different faults.
Sorry.
Nick
Sep 26, 2008 | Acer Aspire L100 PC Desktop
Possible overheating problem for Acer Aspire mini L100
I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
ACER L100 OVERHEAT
Are you comfortable with a little case mod. Just did this myself & solved overheating issue. If interested let me know & I will provide step by step instructions.
Aug 16, 2008 | Acer Aspire L100 PC Desktop
Error Message
sounds like sound drivers.
Install this update to resolve an issue where the Realtek HD Audio Control Panel may not start after you install security update KB925902 (MS07-017) and security update KB928843 (MS07-008).
http://www.microsoft.com/downloads/details.aspx?familyid=74AD4188-3131-429C-8FCB-F7B3B0FD3D86&displaylang=en
Nov 08, 2007 | Acer Aspire L100 PC Desktop
Unwanted System Shut Down
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} ok guys this is the problem i work for Acer and basically if you own an aspire L100 then you have to be prepared to modify your little bad boy because of acers poor design and a crappy little fan the anything inside the case feels like its on holiday in the tropics what you have to do is side mount 2 extra fans with separate 12v supplies and your system will never overheat or die on you if you have any questions on how to do this just email me :-) me
Aug 10, 2007 | Acer Aspire L100 PC Desktop
AcerPower F1 PC Desktop Logo
992 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
