Question about Maytag M7Q08F2ACOM Air Conditioner
Energy Saver setting
Does anyone have a manual for this AC unit - we are wondering what the energy saver setting does?
  • Maytag Master
  • 4,655 Answers
Could not find a manual, but that setting is the setting that you choose to leave on and let the air conditioner decide the most effecient way to run during the day. There are too many ways to approach that answer in a small conversation. There are many things to consider and I will leave you with a link to a PDF that explains better of what I am writing. Sea Breeze
Posted on Jun 20, 2009
I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
Jun 21, 2015 | Hampton Bay Heating & Cooling
My Canon image class MF5350d won't go into energy saver mode anymore
Odds are that some one did some panic button pushing at one time. You need to look in your owners manual or down load one from the web. Or you can go into the user settings and scroll down to were you see a setting for energy save. Good Luck
May 20, 2013 | Office Equipment & Supplies
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
I set ac at energy saver 71 degrees. The ac goes
yeah you have to be carfull the only thing that does is shut the inside fan off it does not mean anything. it is a selling thing
Aug 04, 2009 | Heating & Cooling
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
KitchenAid 24 in. KUDI01FLSS Stainless
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Oct 20, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Reset timer for energy saver mode
Every new unit comes with the user's manuals, and every new unit has free tech support from the vendor. What you are looking for is under the "System Settings" found after pressing "Additional Functions".
Oct 18, 2007 | Canon ImageRunner 3320N Copier
Maytag M7Q08F2ACOM Air Conditioner Logo
195 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
