Question about Dacor DCM24 Convection/Microwave Oven
Dacor dcm24 microwave
Coupler is wobbly. it turns when on but if support and tray are placed on it, it won't turn. how can I check if I just need a new coupler and how to replace it, or do I need to call for service right away. microwave works other than the turntable not turning.
  • Dacor Master
  • 9,085 Answers
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
Here are those part numbers:
66388 Turntable motor
66489 Turntable coupling
You can order either of there here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
I have the Dacor DCM24 microwave and if the table does not spin will the microwave still cook food. I think my turn motor is bad, but wanted to know if I could cook food without it?
Yes! it will continue to cook food, the only difference you may end up with cold spots in the food, rotate plate once or twice to reduce this.
May 30, 2012 | Dacor DCM24 Convection/Microwave Oven
I tried cooking with the convection function in my dacor DCM24 microwave. now the microwave function will not work. the fan comes on, but the turntable doesn't move and there is no heat.
This is almost certainly a bad secondary interlock (bottom door switch) or its mount.
See my help file on door switches here.
You can download the service manual and parts list free from our site.
You can order parts by entering the Dacor part number here.
Oct 28, 2011 | Dacor DCM24 Convection/Microwave Oven
My Dacor microwave does not pop popcorn on Sensor what is the problem
i had that problem. the solution is glass. my turntable is not glass and microwave popcorn must rest on glass to pop. just place a glass dish upside down and cook it on that.
Sep 09, 2011 | Dacor DCM24 Convection/Microwave Oven
Turn table is not turning and microwave is not heating (but still runs)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 22, 2010 | Dacor DCM24 Convection/Microwave Oven
Turntable not turning
you should be able to repair this your self the turntable motor is fairly easy to get to.it does sound as though your motor has gone bad.
Jan 31, 2010 | Dacor DCM24 Convection/Microwave Oven
What is the best microwave popcorn for my dacor microwave we just got it and i thought i would try some microwave popcorn it did not work very well the turntable just keep turning but the popcorn did not...
Put any microwave popcorn on a up side down dish so it is about in the middle of the oven. Make sure you follow the "this side up" instruction on the bag.
I am a microwave pop corn wizzard.
Jan 17, 2010 | Dacor DCM24 Convection/Microwave Oven
Can the Dacor DCM24 be installed in a 19-inch deep
yes / but install still need some air flow in and around the unit . needs air under neath and over the top / and cannot have 0 clearance in back / / ****
Jan 10, 2010 | Dacor DCM24 Convection/Microwave Oven
My Dacor DCM24 microwave/convection oven is brand new and won't pop popcorn--old or new, large or small bag, with twice as much time as is on the bag, power on high. Doesn't work with the popcorn button...
Are you cooking it this way, as shown in the owner's manual?
"Use an overturned 9 or 10 inch oven proof glass pie plate on top of the
turntable when popping bagged microwave popcorn.
You can also use a paper plate in a pinch, but as always, never leave a microwave unattended while it's cooking, since some paper products can have impurities which will allow overheating and possibly fire.
This is a convection oven, so it has a metal turntable tray.
Microwaves cannot penetrate the metal from below like it would on a standard microwave's glass tray, allowing for even heating.
If you've lost your owner's manual, you can get it here.
Oct 21, 2009 | Dacor DCM24 Convection/Microwave Oven
Dacor DCM24 Door is out of alignment
Loosen 3 screws on lower hinge, lift the door to realign, then re-tighten screws.
Jan 29, 2009 | Dacor DCM24 Convection/Microwave Oven
Dacor DCM24 - Security screw/tamper proof hex bit size?
It's a a T20H Torx type or GTXH20-100, available from hardware stores, or places like Lowe's or Wal-Mart.
Some folks just break or bend the post in the middle, then insert a small flat head jeweler's screwdriver in the space between the post & outer edge of the hole. A sharp tap with a hammer will loosen them a bit.
Otherwise, you can use a hacksaw or Dremel tool to cut a groove in them, then use a flat head screwdriver to remove them.
Just be sure that any special grounding screws get put back where they were to ensure proper grounding of the case, an important protection from shock hazard in rare cases of internal wiring breakage.
The Dacor DCM24 is essentially a rebranded Sharp R930A and I have the full service manual here at my site.
As to what's wrong with it, I would say your secondary interlock (bottom door switch) has failed.
The service manual will cover it, but there's additional info here: http://www.microwavedisplay.com/doorsw.txt
The best place to order Sharp parts is Tritronics.
Sep 23, 2008 | Dacor DCM24 Convection/Microwave Oven
Dacor DCM24 Convection/Microwave Oven Logo
355 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
