Question about Lexmark X3550 All-In-One Printer
Incorrect Port Detected
When trying to print on VISTA machine I get an Incorrect Port Detected error message.
Have already downloaded the most recent driver from Lexmark site and still get the error.
  • Anonymous Mar 26, 2014
    I have the printer connected in the correct place.
    Master:
  • 638 Answers
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. CHANGE THE USB WIRE (THE CONNECTION BETWEEN PRINTER AND YOUR PC )IF IT IS TOO OLD.
  3. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  4. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  5. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  6. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  7. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  8. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  9. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 08, 2008
When trying to print message comes up 'incorrect port detection' what does this mean?
It could be that the port for the printer in the Control Panel is not configured correctly. You may refer to this article on No Communications Error When Trying to Print or Scan. If that doesn't help, I would suggest you uninstall the Lexmark software.
Download the updated Lexmark X2350 driver (Windows only) from the Lexmark website at http://bit.ly/i4Axqw. NOTE: Use Vista driver in Windows 7.
Jan 20, 2011 | Lexmark X2350 All-In-One InkJet Printer
Incorrect port detected on 2600
It could be that the port for the printer in the Control Panel is not configured correctly. You may refer to this article on No Communications Error When Trying to Print or Scan. If that doesn't help, I would suggest you uninstall the Lexmark software. Download the updated Lexmark X2600 driver (Windows only) from the Lexmark website at http://bit.ly/aNGYmW. Select your operating system to download the driver. Thanks.
Jan 18, 2011 | Lexmark X2600 InkJet Printer
My lexmark 4300 series says incorrect port detected
Hello!
Yes the problem is with your printer port setting, to view or to correct the printer port setting,
- go to CONTROL PANEL
- click or open Printer or Faxes
- right click your Lexmark printer and click properties
- a menu will appear, choose or click PORT tab
- at the Port tab listing, choose USB port and click ok after choosing the right port.
then you should be able to print properly after the right configuration.
Hope I was able to help.
Jul 23, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark Z35: Problem Communicating with the
Installing like this Lexmark are Plug in Play, Windows automatically detected such devices connected on it. If not then try to use another USB Connector to see which is the problem occur or might be your printer too...
Oct 04, 2009 | Lexmark Z735 InkJet Printer
According to Features and Specs on Lexmarks website, this is a All in One? i.e Fax, Printer, Scan & Copy? also it's a Network type?
If so have you chosen the correct settings via the Printers Dispay and Control Panel? ...... I assume you have and everythinh in Device manager looks good, i.e no Yellow and or Red Icons over anything listed there, especially USB....correct?
If your Vista is the 32 Bit then the driver file should be: cjb5000enOSS.exe (87.7MB)
If Windows Vista x63 then it will be: cjq5000enOSS.exe (132.76MB)
Hope the above helped,
cheers,
Bastian
Jun 02, 2009 | Lexmark X5075 InkJet Printer
Incorrect port detected 926
Try reinstalling the drivers for your printer. You should have a disk that came with the printer. If you don't then you will have to search the Dell website for the drivers. Once you have found them, reinstall them and see how that works out.
Let me know wether this helped or not.
Feb 11, 2009 | Dell 926 All-In-One InkJet Printer
Help
sounds like the settings for your printer are unhappy. try a re installation
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Lexmark X6170 All-In-One InkJet Printer
Hi. I have previously downloaded the driver for the Lexmark X75 printer, but when I try to print -I get the following error message: "Incorrect Port Detected. The current print job has been...
I'm assuming you're using Windows XP. If not, these directions may differ a little.
  1. Click Start > Printers and Faxes.
  2. Right-click on Lexmark X75, and then click on Properties.
  3. Click on the Ports tab.
  4. Find Lexmark X75 under the Printers column (or look for which item under the Port column is checked).
  5. Chances are it somehow got changed to COM or LPT. Find any available USB port and check it. Click Apply.
  6. Try to print. If it doesn't work now, you'll probably get a different error, something like "Cannot Communicate". If that happens, go back to theProperties window and try checking any other USB ports you see there. If there aren't any more to try, you may have to uninstall and reinstall the drivers to get it working.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Help
try with other port if still it is not working change the usb cable
Oct 06, 2007 | Office Equipment & Supplies
Lexmark X3550 All-In-One Printer Logo
1,753 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
