i have a/c model aew24dlh1. my problem is it want come on, the control panel lights up and is operatible, but no action from the unit at all. i installed a direct 10/2 line to 230/208 breaker what else do ineed to do.
How many amps is your breaker. Compare to name plate info. Amps should be listed. Consult an electrician. Saving money is one thing, saving a life is quite another There is no such animal as a 230/208 breaker. These numbers are voltage. You probably wired your high voltage wire into your outside unit disconnect. These wires run into your panel where they are controlled by a breaker. The numbers would be 20,30,40,50,60, etc.... The 10/2 number refers to size and number of strands but also load. Unless your disconnect is wired you won't get natta ...
