Question about Maytag Washing Machines
I have an accute shaking-vibration problem coming out of both the wash&rinse cycle at intermediate speeds when the clothes are at their heaviest!had an A&E tech come out and no help.tryed to tell me i had a weak floor!before he came i had placed a 4x4 under the floor directly under the washer,held up by 2 house jacks.i also placed apiece of plywood directly under the washer before i called for help. all of this has not helped nor did the a&e tech.that they sent out!!he told me i had it as good as i could get it!! and that he couldn't help me!!! this was on june 5.I have since observed this:that the two shock absorbers on the motor side in the rear are much weaker than the two in the front!??is this by design or is this a manufacturing defect??hope you can help us. matag epic z-mdl#mhwz400tq00-serial#hlw1156282 also in high speed, washer runs very smooth! i have also purchased&installed the new antivibration pads,NO HELP! ABOUT READY TO RETURN WASHER OR REQUEST REFUND NEED SOME HELP. carrrid@aol.com phone#252-747-7279 very sincerely, DENNIS RIDER
  • 833 Answers
Vibrations are a problem with all machines in the spin cycle. First, try the machine without clothing and run it through a full cycle. If it doesn't vibrate...we've eliminated damaged equipment. Now, run with just a lightly packed load. If it's okay...the issue is related to excess loading of clothes or the fact that they distributed badly in the prior wash cycle. This can happen any time to any machine. Try re-arranging them.
What else you can do:
Make sure the machine is on a level surface that is FIRM ...seems you may have done that but make sure that the machine itself is level (use a spirit level to check!) with all 4 legs firmly touching the surface. To test, push on the top side edges of the machine to try to 'rock' it. It MUST NOT move. Some machines are more intolerant than others to imbalance. I doubt the shock absorbers you mention are the problem. If you can't get satisfaction with these steps, your dealer may be your only option.
Posted on Jun 08, 2008
LG Tromm Steam Washer Cycle is complete and the stuff is so wet that they have to wrung by hand to even put they on a clothes line. Can washer be put on spin only? How?
call a technician as it indicates that the cycle from rinse, spin is not progressing to spin only
rinse,spin is a low speed spin to facilitate the rinse and to balance out the clothes ready for the fast speed spin cycle
Feb 25, 2017 | LG Washing Machines
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
We have an Ultima washing machine and creases the cloths very badly any suggestions please
The amount of creasing you will get is directly related to the speed you select for the final spin dry cycle and the spin after the first wash cycle which occurs prior to the rinse cycle. The higher the speed and the longer it goes for the more the clothes will crease.
Experiment with different spin speeds on your machine for clothing that is subject to the creasing problem. Also do not put too many items in the machine for a wash as many people do as this will contribute to creasing. Always under load your machine for every wash cycle.
Spin drying is a compromise between creasing and maximum water removal. If you want less creasing you will need to select a more gentle spin dry speed but you will also have the clothes coming out of the machine with a higher water content and they will take a bit longer to dry. The spin time on the program may also be shorter.
In my own machines I use a gentle wash and spin cycle for all clothing that I don't want heavily creased. Running it on a wash cycle with a high and longer spin speed when the machine is spinning the clothes after the initial wash, and then again after the final rinse, will thoroughly crease the clothes every time.
Also bear in mind that different fabrics that are suitable for machine washing will perform differently and some are just too subject to creasing even if you use the most gentle wash, rinse and spin cycle. Hence you can take 2 different 100% cotton fabrics out of a machine and hang them to dry and one will be almost crease free and the other will be thoroughly creased. With these fabrics that are just very subject to wash creasing, it is better to hand wash and rinse them. Then after rinsing drip dry them or put them in the machine and spin them for 1 -2 minutes maximum just to get some of the water out and hang dry them.
Dec 28, 2015 | Hotpoint Washing Machines
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
The washing detergent doesn't wash out of the clothes it leaves marks on the fabric. what is wrong?
Too many clothes in the load , reduce by 25%
Switch to an old fashioned soap powder that has more agents in it to help it dissolve
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Shakes during spin cycle
Most out of balance problems are from the clothes in it. Stop it, move the clothes around - kind of even out the load and try again.
Mar 29, 2009 | Washing Machines
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Loud grinding/scraping/rattling noise at rinse cycle
The balance sensor is likely failed.
Check the shock absorbers and springs for breakage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Kenmore 23832 top load washer
lalocke If the load is not properly balnced, your washer will shake too much on the spin cycle and it wlll never go on full speed. Gendos...post back
Mar 01, 2007 | Kenmore 23822 Top Load Washer
Washing Machines Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
