Question about Panasonic Computers & Internet
Ref.: Gateway Computer w/Performance 733, Serial No. 0019912421. Received unit semi-disassembled. Need cableing info. to install the Panasonic 1.44-MB Disk Drive and Philips 8X-4X-32X Drive.
  • 3,940 Answers
The specifications of the system are here:
http://support.gateway.com/support/srt/docs.asp?sn=0019912421
The upgrading section here should give you some information about where connecitons go inside the case
http://support.gateway.com/s/Manuals/Desktops/8512980.pdf
Posted on Jun 08, 2008
Hello, I would like to know if I can use a
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway fpd1520 - 15 Lcd Display White
Gateway fpd1530
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
I have a PANASONIC NSDN-W59 MODEL : 08545-00S61 REF : CQ-US0901CJ SERIAL: 76043 in my car and i change my battery now its need a code to unlock it. now what do i do?
Apr 04, 2013 | Panasonic Car Audio & Video
I can't open my thomson gateway
What's the error message?Have you tried to go to the exact modem page?
1. open internet explorer2. type the numbers 192.168.1.254 on the address bar then press enter3. you will be routed to thomson page settings if you received any message stating error like can not display page then you need to check if the cables are properly connected.4. if still can not connect, go to the start menu icon5. select the run icon or search bar6. type cmd then press enter7. you should received a black screen8. from the black screen type ipconfig then press enter9. you should received the info like IP ADDRESS, SUBNET MASK and DEFAULT GATEWAY.10. copy the default gateway and type it in the address bar of your internet explorer then press enter11. if you have not received these information (ip address, subnet mask and default gateway) on the black screen after typing the ipconfig then check the error "media state disconnected" which means that your pc and your thompson is not communicating, here you need to try different network cable to isolate issues for the problem might be the cable, network cable port at the back of your pc or the network cable port at the back of the thomson.
kindly rate rate this post, thanks
Dec 31, 2011 | Computers & Internet
Gateway ma7 put in new hard drive, cannot connect to the internet via wireless Help?
Did you install the wireless drivers? On a second computer, go online, download the drivers, copy to a USB stick and install them on the Gateway. If you can connect with an ethernet cable then you can do it from the Gateway.
You might have received a DRIVERS DISK with the gateway. That will have what you need also.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Computers & Internet
How do I get the caller ID information from the Panasonic KX-TA824 through the serial port connection, in real time? I connected a serial cable from the unit to my computer, and it shows the call log,...
The correct answer is, "you don't". The TD and greater series (including the TAW) has a "AN" and "RA" feature that pre-displays CID as the call is ringing, the TA and lower does not.
Carl
Oct 10, 2010 | Panasonic KX-TA824PK Phone
No sound from speakers and microphone not working
  • Firstly ,make sure that you have installed the audio driver on your PC. Or if u didnt install it, you can download and install it from Gateway Site here: http://support.gateway.com/s/PC/R/1009151/1009151nv.shtml
  • And also check the audio cable connector. (Connect the audio cable / speaker to the sound card of your computer.)
You could find User manual here: LINK
Have a nice day! you could ask me if you need more in assist, i would be glad to help :) (more info would be useful)
regards
Apr 17, 2010 | Gateway GT5220 PC Desktop
What ram does a Gateway flexatxstc bro essential 733 take and how
There is an easy way, and there is a hard way. The easy way requires you to get access to her computer and download Everest Home Edition. After installing the application open it up and find out if you're currently using SDRAM, DDR, DDR2, or something else. You will have to match the memory in order for it to work together.
Now for the hard way. You will need to find a way to open the computer to take a peek inside. Pop out the memory stick(s) by opening the pins holding the memory shown in this picture. Afterward look at the bottom of the memory stick(s). You're looking for the noticeable difference between DDR and SDR as depicted here.
Once again, you will need to match the memory types to ensure that they will work together. Also, please don't insert an odd (3, 5, 7, etc...) number of memory sticks (1 stick being the exception), some motherboards can't handle it.
Let us know what you find out. All the best in helping out ***********-in-Law!
Jan 30, 2009 | Gateway Computers & Internet
Need drivers for a GP7-733 Gateway Desktop
you can download all drivers for gateway laptops at the following site for free http://support.gateway.com/support/drivers/dlcenter.asp
my friend has a gateway and she had the same problem.
more help needed then email me on milliprowd21@yahoo.co.uk
thanks
matt
Aug 21, 2008 | Computers & Internet
Computers & Internet Logo
335 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
