Question about Frigidaire Kitchen Ranges
I have a Frigidaire Gallery gas oven (electronic digital controls). Neither oven nor broiler is lighting. Stovetop burners light fine.
  • 868 Answers
Have to check if there is power at the oven & broiler first.Maybe a bad thermostat located in back of oven wall.
Posted on Jun 09, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
What is wrong with our GE Profile Gas Range? After using the broiler and two burners simultaneously, the electronic controls go black. We can manually light stovetop burners but oven does not work.
On the back of the stove are 2 blower fans just under the cooktop. They are cooling fans to keep the controls from overheating. They are a long tube type fan and are left and right side. My guess is one or both are not coming on. They are controlled by a round disk temp control also under the cooktop. At a preset temp these fans should come on and keep all the control area cool enough to stop any damage. The fans need tested and maybe the temp control needs replaced.
Mar 23, 2015 | GE Profile 30" Slide-In Gas Range -...
Propane oven won't light
Can you post more details like: Does the oven ignitor come on (glow orange)? Can you hear the oven gas valve click open and/or smell gas? Do all the stovetop burners work fine? Have you checked your propane tank to be sure you are not out of gas?
Mar 13, 2014 | Amana AGR4433XD 30" Freestanding Gas Range...
The oven will not light and is throwing a breaker. Is this something fixable? It has been slow to light for a while now, and we usually have to turn on one of the stovetop burners in order to get the oven...
can you access the ignition module,if so try using one of the connections from the module that ignites a stove top burner and see if this line connected to the oven lights the oven now and doesn't throw the breaker,then you would know that section of the module is defective
Feb 11, 2010 | Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
Drexia clarifying previous post on gas range stovetop cleaning.
I have found that kitchen cleanser and a crub pad along with good old fashioned elbow grease is your best bet...
The fine scratches might come out with a good rubbing compound like the type used on car finishes...
Apr 10, 2009 | Frigidaire Gallery 30" Self-Cleaning...
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
239 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
