Question about Dryers
GE Dryer model#DWSR483EA1WW
Dryer makes loud squealing noise when drum goes faster.
  • Anonymous Jun 12, 2008
    GE Dryer Model DHSR333EV little over 5 years old squeals constantly and loudly - more so at beginning of cycle when clothes are heavy and wet. Dries OK.
You need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Posted on Jun 21, 2008
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Our dryer was making a loud squeaking noise for a while now it is tripping the circuit breaker as soon as it is started what do you think is our problem.
The drum rides on a bearing in the rear which cause the squeal. The squeal eventually cuts into the bearing and the whole drum begins to rub against the heating element. This causes the breaker to trip.
How it works: GE clothes dryer
Jan 05, 2011 | GE Dryers
Dryer makes a loud squealing noise
the rear bearing is gone,ge has a bearing kit that goes on the back of the drum and hooks onto the back wall,the bearing wears down and gets noisy,call your parts store,give them the model number and they'll give you the parts you need
Dec 03, 2010 | GE Spacemaker Washer and Dryer Electric...
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Noisy dryer......when engaged...making squeaking/squealing noise.
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Loud sqealing nose in dryer
If this is a GE dryer, replace the dryer drum bushing on the rear of the drum support.
Mar 23, 2009 | GE Dryers
Dryers Logo
788 people viewed this question
Top Dryers Experts
