Question about RCA HD52W59 HDTV Projection Television
Part? Where can I get a power supply board for my RCA HD52W59yx22, Chassis ITC222A. There is a burnt spot on a board in the back of the tv where the Flyback transformer is plugged into. Thanks.
  • c3r34lxi113r Dec 15, 2008
    Hi I have the same problem with my RCA D52W20, The position of the part that burnt out is k-6. It burned a hole right through the board. I found this part on Partsstore.com, RCA Part Number: 258762R but I don't know if its the right part, I really need the whole board. I need to know the part number of my board the only numbers I can find on it are PSB 850 and PSB 21900 00 01 but those numbers don't work anywhere.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Go to Tritronics or Union or Andrews electronics for RCA parts. They all have websites.
Posted on Jun 10, 2008
Where is the supply board to replace the capacitors ?
Need the model number of the set to help with the issue, But usually there are three caps on the deflection board if you have the ATC221, ITC222 0r ITC222a chassis rca
Mar 23, 2012 | RCA Televison & Video
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
RCA R52WH73 won't power on
most likely the flyback or cl031 has burnt up. You can get the replacement ITC222A deflection board from www.tvrepairworld.com
Mar 22, 2010 | Televison & Video
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
RCA 52" Convergence Problem
Replace the convergence power supply. You can get the ITC222A convergence power supply board at the following link under RCA circuit boards.
http://www.tvrepairworld.com/
Jul 24, 2009 | RCA HD52W59 HDTV Projection Television
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Will not fully come up.
2200mfd cap on the HV Power Supply board about mid way on the chassis, if it is bulged at the top, REPLACE IT.....Let me know! Also, cold solder joints on same...
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
Tv will not power up
Flyback transfromer is bad,part number 259296,part is around 60.00,you might find it at mcm electronics,phone number is 1-800-543-4330
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
252 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
