Question about D-Link Computers & Internet
Modem D-link 500G
Hi!
Could you tell me how can i setup my modem to open door for allow me to be a host in the game using my ip?
  • zuri08 Jun 10, 2008
    Hi!
    I use a combat simulator that require my ip to allow me to be a host,but I am using local network wich gives me an internal IP.So the others from internet can not conect to mine.
    Could you help me solving this problem?
    Thanks a lot!
    Uriel p. Mello
Please explain little more better.
Posted on Jun 09, 2008
Would like to host a game thru my motorola modem/router
You need to look for something on your router called Static NAT and configure it to point to your internal IP address.  You also need to find out what ports your NASCAR game advertises itself on...it's usually high ports (20000-30000).  ONce you find out the port(s), you can create a custom service on your router for those ports, and when you configure Static NAT, it should ask what 'service' you want to advertise.  This basically tells the router to forward all inbound traffic, looking for those particular ports, directly to your IP address, which will allow users on the Internet to see your game server.
Cheers!
Apr 18, 2009 | Arris WR850G Router (DHWR850G)
Friend cannot conect to me while im the host server.
 Each computer on the router is assigned an ip if DHCP is enabled in the router. This is known as your inhouse IP and you will need these to forward ports.
On each computer connected to the router open cmd (command prompt) and type
ipconfig /all
Make note of the ip assigned for each machine.
Open your router setup and enable DHCP if is isn't already. Save changes.
Locate Port Forwarding or Advanced Routing.
Create a rule for each machine. You can name them anything you like, such as machine1, machine2...
Select TCP for the protocol. You can select a port range in the ports boxes. In the IP box you will type the ip for each machine and select enable. Save Changes.
Reboot everything, machines, router and modem.
Also note some routers have a gaming tab which will make this easier to setup.
Good luck
Mar 30, 2009 | Belkin Computers & Internet
Belkin 54 g wireless router....cant find on the net. need to port forward to host blizzard.net games HELP!
Make sure your private IP address is statically set.  Your public IP address is obtained from your ISP and is what other users will be connecting to.  You can not manipulate your public IP address so if your ISP is running DHCP, it is very possible that your public address is changing.  Also if you are frequently disconnecting your modem, it is possible your ISP is leasing you a new public IP address each time.  So try to keep things as static as possible.  As far as the battle net stuff.
Diablo, Warcraft II Battle.net Edition, and StarCraft:
Allow port 6112-6119 TCP and UDP out and in
Diablo II:
Allow port 6112 TCP out and allow established sessions in
Allow port 4000 TCP out (realm games)
Allow port 4000 TCP out and in (hosting open games only)
Warcraft III:
Allow port 6112 TCP in (hosting custom games)
Allow port 6113-6119 TCP out and in (hosting custom games if you've changed the default port in the Options/Gameplay screen)
If you are still having problems after you open up the required ports, try opening 116(TCP) and 118(TCP). I don't really know if these ports are required or not.
I have had people tell me that opening up those two ports have helped them connect to battle.net.
Hope that helps.  For manipulating ports in your router I suggest consulting your user manual, or online FAQ.  Save your router config before applying any changes, and always remember, opening up ports subjects you to different types of security threats so be aware that is a risk you are taking.
Mar 12, 2009 | Belkin Computers & Internet
My modem and my ip
You need to configure the modem for it to allow game hosting. Enable NAT/GAMING setting of your modem. You can do so by pulling its interface and configure the settings from there. The interface of the modem can be pulled up by typing the default gateway of the modem in the address bar of a browser.
Hope that helps. Enjoy your game sessions!
Mar 07, 2009 | 3Com OfficeConnect 56K Business Modem...
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Linksys Wireless-G WRT54G
Try the following on your router
1.) if internal firewall of router is activated, try to disable it.
2.) re-check your DNS settings in the router.
3.) Don't put as local ip address the IP address of the ADSL modem!
4.) Last but not least: if everything fails use static IP setup
Hope it helps...
jowunger
Jul 22, 2008 | Linksys Wireless-G WRT54G Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Ip and proxy error
well, if you know how to setup the ip addresses manually both on your modem / router and on the ps3 i recommend you do that... but bear in mind that your dhcp server (on your modem / router) should prohibit automatic assignment of that same ip address with your ps3... for that you have to specify a range of automatically assignable ip addresses apart from your ps3...
if you have the dmz (demilitarized zone) option on your modem / router, set it up for the ip address of your ps3, which you've setup manually...
example:
router ip: 192.168.2.1
ps3 ip: 192.168.2.10
ip address pool: 192.168.2.100 - 192.168.2.250 (this shpould be manually setup not to interfere with the fixed ip address of the ps3)
dmz host: 192.168.2.10 (ip address of the ps3, which enables "opens" all of the ports for this ip address)
apart from that if you use any proxy servers to connect to the net, you have to specify these in ps3 settings as well...
there are a lot of threads on various forums on how to tweak your network connection to optimize for ps3...
i hope this solves your problem...
Feb 19, 2008 | Sony Playstation 3 (PS3) Console
D Link 604 will not connect to internet
Hi Goldy,
The 604 should setup easily. Make sure you have it set to automatically get IP if you are using Cable, and for PPPOE if you are using DSL.
Once you have it setup. Shut down everything. Plug in the modem, wait 2 min. This allows the modem to get the info it needs from your ISP. Then bootup the 604. Wait 2 min, for it to get the info it needs from the modem, then boot up your computers.
Got to start>run and type in CMD. In the black box that opens, type in IPCONFIG. Your IP listed should be 192.168.x.x. THe X's can be any number from 1 to 253. If the IP is 169.xxx.x.x, you are not getting data from the 604. Check your firewalls, expecially if you are using a third party one, like Norton.
Jan 06, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Bridge RCA Thomson DCM315R
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
Note:
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
Computers & Internet Logo
100 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
