Question about Microsoft Xbox 360 Console
Not reading cds.
I've had my xbox 360 for several months without a problem until 2 days ago. When I put in a game, it will try to load it and then a white screen comes up reading "to play this disc, put in an xbox360 console", and then has some chineese writing along with it. Alson when its not reading the disc ill take it out and try to clean it, but when i did that I noticed it had rings around it. So then i thought it might of been just an old disc but the 360 console wont even play my brand new game "rainbow 2 Las Vagas". PLZ what can i do?
    Problem Solver:
  • 3 Answers
Now.. if it's four red rings, check your component cables, unplug them, then plug them back in, if it's only three lights flashing with the top-right quadrant remaining idle, then there is a problem with your hard drive and you have to send it in for repairs.. but as far as the fact that it won't play any games, try to get a disc that will clean the eye of the console something like "Maxell" player cleaner, that usually works.. if that doesn't help.. sorry
Posted on Jun 08, 2008
My 360 only plays cds or dvd s wont play games please advise
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
Feb 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 will not read cds of any sort, no error message
It appears your laser lens has bit the dust. It's not too expensive to replace it. you can purchase one here.
The instructions can be found here
Feb 26, 2008 | Microsoft Xbox 360 Console
Xbox 360 plays DVDs but not games.
i had the same problem sounds like your lazer or a chance the dvd rom is not paird to *********** board
Sep 23, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont read my games only dvds and cds
that means it wants you to save it to the harddrive and play it there but i suggest you take it to get repaired or buy a new one
Jul 31, 2009 | Microsoft Xbox 360 Console
System won't read games and makes buzzing noise
Is it a copied disk? this only happens to those types of disk. Try contacting Microsoft.
Dec 23, 2008 | Microsoft Xbox 360 Console
Xbox 360 plays CDs n DVDs but wont play my games, plz help
try calling microsoft again...and if no luck...then you might have to find a replacement cd drive...you can probably get one off of ebay.
Jun 28, 2008 | Microsoft Xbox 360 Console
WON'T LOAD GAMES IT SAYS PUT A XBOX 360 GAME IN
Clean cds. attach harddrive and reattach it?
Jan 31, 2008 | Microsoft Xbox 360 Console
Help: Put 360 games in console, wont load says "put in xbox 360" no red lights?
Ok I had the same problem try this if this doesn't solve your problem call Microsoft.
First, Unplug everything including harddrive.
Next, Wait thirty seconds.
Then, Plug everything even harddrive.
Finally, Try it out see if it works. If it doesn't call Microsoft.
1800-4MYXBOX / 1800-4699869
Dec 21, 2007 | Microsoft Xbox 360 Console
Put this in an xbox 360 console
Did you try using a cd lens cleaner in the XBox 360 dvd drive? Check the cds that they are not scratched, and you could have your son try the discs in another XBox 360.
Nov 06, 2007 | Microsoft Xbox 360 Console
Brand New XBox 360 will not read discs of any sort
phone ms, or you got an expensive paperweight
Oct 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
97 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
