Question about Gaggenau EB 270/271 Electric Single Oven
No Manual How do you reset the clock and what are the functions of the Tick Button and the other two buttons
    Problem Solver:
  • 12 Answers
To set the clock:
1. Press the clock key 3 times until the hr/min icon flash.
2. Press the + or - key until you come to your desired time.
3. Press the confirmation (key or tick) key.
Posted on Sep 01, 2008
I have a new Neff U15E52N3GB oven and I have to reprogram the clock each time I want to use it. Am I missing something on the original set up or is it a Naff Neff?
you are, that sounds like your setting the timer for cooking not the clock.....switch the hole thing off at the wall then put it back on, the clock should flash, then set it, check the manual for button config.
infact i just read it, & its on page 10 2nd paragraph on right hand side...........
You can only change the clock when no other clock function is
active.
ie switch it off & back on at the wall.
1.Press the < > clock function button repeatedly until
the< > O(pic of a clock) and symbols light up.
2. Set the clock using the rotary selector.
The setting is applied automatically
Dec 12, 2014 | Neff Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Hi have a ge profile double wall oven electric with convection on top model jkp54. Keypad has stopped functioning hence oven does not work. The only exception is that when the clock button is pressed the...
do u have the manual for this oven , there must be a reset somewhere in the manual , the best answer here is to goto there website and start there to find out if this is a known issue with these models and if it is an easy fix , that is the best place to start .good luck
May 19, 2014 | Ovens
Dacor ecs230 clock button is not working
there may be a backup battery built in to this unit to keep the clock running in case the power goes out. depending on the age of the unit, it may need to be replaced. the battery size and number as well as it's location should be in the owner's manual.
Aug 25, 2009 | Dacor ECS230 Epicure Electric Double Oven
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
I need to reset the clock on my AEG cooker model No S75408 KG
I am assuming you have a touch pad for the clock. You can hold down the time button for a few seconds an it should start blinking. If it doesn't work, try pushing the "set" button for a few seconds. Usually, you can find it by trying all of the buttons til you get the right one. Then, you can adjust the time by moving the up and down arrows.
Jan 29, 2009 | Ovens
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Time flashes ...No other electronic button function
You may have the dreaded F7 problem. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. I have shared this fix with over 1600 folks and most report success. You can email me at hutchipop@yahoo.com
Regards,
Charlie Popeck, P.E.
Consulting Engineer
Mar 09, 2008 | GE JRS04 Electric Single Oven
Clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Feb 06, 2008 | Neff B1641 Single circotherm super...
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Gaggenau EB 270/271 Electric Single Oven Logo
621 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
