HP Color LaserJet 2600n Printer Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There was bits of paper, from a stuck edge from a sheet of business cards that I think are perhaps still in the printer. When I print a colour sheet the alignment is off, printing black and white seems OK.
Seeker5211
Level 3:
Genius:
  • Master 1,089 Answers
  • Posted on Oct 25, 2010
Seeker5211
Master
Level 3:
Genius:
Answers
1089
Questions
Helped
617759
Points
2611
What do you mean by alignment?
If you mean that the colours are misaligned, run a full calibration. Repeat it three times and then try your printing.
If bits of the business cards were left in the printer - it should affect the colour printing as well as B + W. You would also be getting paper jams.
2answers
Why won't my Epson printer Artisan 835 print sheets of Avery clean edge business cards?
Rubber.synthetic Rollers worn or bad, try cleaning with solvent before replacing . Look online for roller cleaner.
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
I am printing postcards which get stuck in the printer during the last 2 inches of printing. What can I do to fix this? The printer is HP officejet 6110 all-in-one.
How stiff is the card stock? Some cards cannot feed if the printer rolls the card to print on it. (This one does)
I have taped cards to a full size sheet of paper and run that through.
Usually this means the paper is too stiff.
You can try cleaning the paper feedroller with a rag with a bit of windex on it. (This roller is above the paper tray where the paper loads in.)
7helpful
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    1helpful
    2answers
    Problem printing business cards
    I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
    1helpful
    Printing business cards
    Feed sheets through front manuel feed slot.
    base tray is mainly for up to 90grm paper,anything heavier
    can feed for a time but tends to fault.also try and clean the
    paper pick up rollers regularly.
    mongrelken.
    1helpful
    Repeated paper jam in fuser
    Fuser's orange roller is not meant to be wrinkled, if this is then I would recommend you replace it (just slides out) pic below
    b4eead5.jpg If printing on card, you need to feed via manual bypass and exit from the back, not on the top, aka the "face up tray." Tray pulls out from rear. Rear tray will only stack a few card sheets at once.
    Setting on printer's control panel must be set to card/heavy paper type on manual bypass tray
    Their may still be some card in fuser causing jams.
    Please rate as FIxya or post back,
    Cheers
    S. :-)
    Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
    To do a Default Setting Mode to an Epson LX300+, you need to:
    1. Power OFF the printer (for at least 10 seconds or more);
    2. Press Tear Off button while simultaneously powering ON;
    3. Release button, maintain power ON, printer will print basic/default settings.
    At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
    Should you want to do a printer self-test on an Epson LX300+:
    Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
    * Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
    * While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
    * Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
    * Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
    * Press the PAUSE button. The printer begins printing the self test.
    * To stop printing temporarily, press the PAUSE button.
    * To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
    Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
    Good luck and kind regards.
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
