LCD TV no pictures but sounds
TV all of a sudden has gone blank and only gives out channel sounds but no pictures.
  • jkeastcoast Jun 29, 2008
    Only 11 months old, picture will flick on for one second when turned on then go out and no picture whatsoever, although sound works normally. Can change channels and hear each channel but no picture. Tried cables, plugged it in other working cable boxes, tried different inputs, etc.. Tried cold restart, no picture. Some gizzmo inside has given up.
Cheak cables try other cables old style yellow to see the pic then go in box tell it hdmi output or coumpunt whatever uuse try differnt ports
Posted on Jun 08, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Emerson TV no picture, but still have sound
If this is an LCD TV, show a flash light (torch light) on the screen from a safe distance.
If you can see the picture, the backlight has gone off and might need
of a qualified service technician.
Aug 05, 2012 | Emerson Televison & Video
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
All of a sudden the sound on our LCD tv has gone. We've checked all the cables are in correctly and even though the picture is perfect we have no sound. SAMSUNG SYNCMASTER 741MP
Connect the cable directly (bypassing the cablebox)and
set menu to cable channels ,
tune to channel 3 or such and do you have sound now.
if not the amp is out , you might just consider using external speakers as they will sound better anyway.
Feb 25, 2008 | Televison & Video
Picture gone from TV Model LE46M51B
I suspect that your backlight has gone out. If you shine a light on the screen can you see remnants of the picture that should be displaying? If so, it's definitely the backlight, and most likely the power inverter for the backlight. You can probably find a replacement inverter, but you may need a repair manual to install it. I'd recommend checking the warranty status first and sending it in for repair if you can.
Feb 17, 2008 | Televison & Video
RCA tv
Check the signal type. It may be set incorrectly. Change the channel. You may be on a blank channel. Check to see if the TV is tuned to channel 3 or 4 if you are watching a videotape. Check the TV/VCR button on the VCR is in the correct mode by pressing the TV/VCR button on your VCR.
Aug 11, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
VCR not working with TV
What you state cannot be logical. If picture is freezing, then the VCR is at fault. But you state that the VCR works fine when played, and viewed on another TV. So, the only explanation I can think of is that there is some thing faulty with your VCR. Probably, when you play a tape, the picture freezes. This could be 'cos the Capstan motor of the VCR freezes. Common problem with aged VCRs. Just requires a spot of grease, and service. IT CANNOT BE THE TV AT FAULT!!!!
Aug 22, 2006 | Toshiba CZ32T31 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
