Question about Canon PIXMA iP3000 InkJet Photo Printer
Not printing despite new cartridge
Although there is a new cartridge installed it still does not function. It goes through the motions of printing but no print appears on the paper. Can you help please.
  • 1 more comment
  • Jennie V Jun 16, 2008
    Thanks for doming back to me but after a few days I was able to print a document. This happened after changing the cartridge.
  • ptsol Jun 19, 2008
    will not print black even with new cartridge and several deep cleaning attempts, tried to clean print head, colours ok
  • Steve Allison
    Steve Allison May 11, 2010
    "Cartridge?"
    Did you mean an ink cartridge or the printhead itself?
Spoke to canon agents. they say head is stuffed and printer needs service. +/- r900
Posted on Jun 11, 2008
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
Epson Stylus C88 - New Epson Factory ink cartridges. Nothing prints, although printer goes through the motions of printing. What could be wrong? Ink levels are fine.
You should run a nozzle check to verify if the heads are printing all the inks correctly. If the pattern is incomplete you need to run head cleanings.
Apr 30, 2010 | Epson Stylus C88 InkJet Photo Printer
Not printing although going through the motions!
Are you using the origianl cartridge, Some refilled cartridges may create such problems.
Jan 21, 2010 | HP DeskJet 895cxi InkJet Printer
Put in new cartridge and unit will not print. Goes through all of the motions but doesn't print. Printed many pages before "low on ink" message. Why does it not print now?
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Sep 04, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark x1240 will not print
did you tried to set the properties to mono ?
Apr 12, 2008 | Lexmark X1240 All-In-One InkJet Printer
Printer wont print
Not sure but this printer may not be compatable with vista. OR.... you say it goes through the motions, does a page of paper come out? Did you try a different cartridge?
Aug 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
96 people viewed this question
old marine
old marine
