Ethernet cable does not fit into computer
I'm trying to connect to the internet but my ethernet cable does not fit into my computer
  • shaz_brown Oct 30, 2008
    i have been told that i need to have a ethernet cable put into my computer but i dont know where, how much or how easy it is to fit, does it just plug in or what??? i have a wireless adapter but my internet supplier says i need a wired connection first.. please help!!!!
You might be trying to plug the ethernet cable into the modem. This is smaller than the ethernet connectionbut looks the same. If there is no ethernet connection on the computer you might need to have a NIC card install.
Posted on Jun 12, 2008
How to connect pc to thinkland
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Disconnect ALL cables from the modem and routericon1.png: internet cable, power, (and ethernet). You can leave the computers on, but if this doesn't work , try it with the computers off.
Connect the modem, cableicon1.png, ethernet, and power. modem .
Connect power on router, Wait until router has a connection
then connect ethernet from modem,
then one by one connect the computer ethernet lines to the router.
Feb 07, 2014 | Computers & Internet
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
My travelmate 240 will not connect to the internet via an ethernet cable. I have a bt home hub with a wireless laptop and PC with ethernet cable running OK. I have tried with the known good ethernet cable...
The best way to check if the computer can access to Internet is to boot the computer to "Safemode with Netwroking", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode with Networking" from the Advance boot menu. Try to connect to internet. If you are able to connect to Internet then the issue is with the firewall on you computer, contact the firewall manufacture or do settings. If you are still unable to connect to Internet, then the internet setting are not correct, you may need to contact the ISP or try reseeting the Internet Explorer.
Thanks and Regards,
Anil.B.R
Sep 07, 2010 | Acer Computers & Internet
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
I don't know how to connect my router. please help
If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
Enthernet connection
Ethernet connection is a LAN or a CAT cable
One end of that cable will connect at the back of ur router box that u will have with u or u will get it from ur ISP .
and the other end of that cable goes to the back of ur pc in the jack which says LAN or try to plug it in any socket which fits properly.
u will a light that will start flashing at the back of ur back when u plug that cable in
to check whether u system supports ethernet connection or not
1. right click on my computer
2. goto properties
3. goto hardware
4. goto device manager
5. u will find network adapters there
click on the plus sign on the left side of network adapters
plus sign will change to minus
under network adapters look for an ethernet adapter or network controller
or 10/100 or 10/1000 fast ethernet NIC ( network interface card )
if u have one , then ur pc supports ethernet connection
U just have to connect the ethernet cabel to ur router box and at the back of ur pc and u just have to open internet explorer and ur internet would start working...
if u dont have ethernet cable with u or ur system does not have an ether net socket in ur system , u can goto any computer shop and get an ethernet cable and a socket for ur system
If u dont want to do that , u can go for a USB cable connection with ur pc or a wireless connection....
reply back if u face any further problems
Feb 19, 2008 | Computers & Internet
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
