Question about RCA Televison & Video
Black border around edges of tv screen closing in. goes from 3 inches sometimes,up to 5to6 inches.lost manual dont know how to get it off.
    President:
  • 2,712 Answers
You will most likely need to replace the DM module on the board, which is failing. I wouldn't recommend you doing this yourself. Please consult a qualified TV technician to do this for you.
You can find a repair service near your area by posting your zip code in the boxed marked "Repair Service" at the side of this post window..
Posted on Jun 11, 2008
  • Swilin Sampson
    Swilin Sampson Jun 11, 2008
    The issue could also be faulty convergence IC's. If they are found to be faulty, please replace both at the same time.
    Also make sure that you have selected the proper viewing dimensions from within your settings..
    Sergeant:
    Champion:
  • 230 Answers
You can get the manual here
http://www.retrevo.com/samples/RCA-Projection-TV-manuals.html
and also check this one
http://shopping.yahoo.com/s:Televisions:3820-Television%20Technology=Projection:4168-Brand=RCA
    Guru:
  • 1,894 Answers
I think this is a convergence problem
    Sergeant:
    Champion:
  • 310 Answers
Can u tell me ur model no....................
  • 3,940 Answers
    Genius:
  • 1,847 Answers
Chk the horzental and vertical setting of the screen.
Posted on Jun 08, 2008
LC-43LB371U How can I get the manual for this TV?
Contact the manufacturer. The manual you need may be available on their website.
Jun 18, 2015 | Sharp Televison & Video
Why does the screen have Black Border around the picture , picture distorted?
There are connectors and circuitry that control the vertical and horizontal picture image generation that need to be at the edges of the screen. The border simply covers these connectors and circuitry so the user cannot see it. Newer models of flat panel TV's solve this problem better to get more picture real-estate to the user. Flat panel TV's are not like the original CRT (cathode-ray) TV's of the past that had borders to conceal a non-linear distortion that occurred at the edges.
Jun 23, 2014 | LG 37LC7D 37 in. LCD HDTV
I have just brought a hdmi cable and connected it to my laptop. but for some reason the picture is to small with a 3 inch black border around the edge on my tv. how can i make the picture fit the tv screen...
I suggest try to check the Properties of the Video Card Driver and Check for the Aspect Ratio and adjust it to 100% sometimes its not named Aspect Ratio but you can see it under video or display options that's how you can fix your display problem.
May 18, 2011 | Computers & Internet
This is a 26 inch toshiba lcd flat screen. the power went out for a while now I cannot get a full screen, just a black border around the edges. can you please advise me on what could be wrong, thanks will
Dear Friend: when TV is unplugged for a while, it goes into "factory default" settings. That's why you have 4:3 format of your picture settings, instead of "wide" or 16:9. check TV "screen" or "picture format" button, if it present on your TV(not a cable or satellite) remote control. If not, enter "menu" and find "display settings" and adjust it accordingly. Also: same issue might happen to your "boxes" Cable or Satellite. If those were without power for a while, same thing might happen to those. Check "menu" or call your provider, if needed.
Good luck,
Alex.
Apr 19, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
Screen turns black except for one inch around the outer edge
Use the tv/cap/text button to turn off the text box function of the closed captioning.
Jan 26, 2009 | Sansui COM3101 13" TV/VCR
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
A black box appears on the screen
Just happened to see your black box problem associated with your T.V.; Thought I would pass along an idea for you to check into, and let me know if it helped...Check into whether or not it has a onscreen text block mode, if it gets into this mode by accidentally pressing the wrong buttons on the remote and or TV, it could and I have seen, at least with zeniths, a big black box which will cover the whole screen except for a 2 to 4 inch border around the box and outer edge of the screen...if this is the case, find someone familiar with the correct setting for the set associated with this problem, and get it back into the right mode....Hope this helps..T.
Jan 15, 2008 | Haier 20" TV/DVD Combo
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Picture does not bleed to edge
this symptom is caused by a poor regulation in the power supply circuit. too low dc supply voltage will result to insufficient deflection, both vertically and horizontally. black borders appear around the raster. receivers generally use regulator in the main power supply to set the dc supply voltage at the value that will allow the picture to fill the screen with a little overscan. defective regulator can result in a small raster. most modern receivers today are using ic (integrated cirduit) regulator. but if you are not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Feb 27, 2007 | Toshiba 27A43 27" TV
Black square covering up most of the screen
Try goeing into your Menu and see if you have the closed Caption on that will produce a black box on the screen if you have the owners manual look in there,if you don't have it you can go on line and download it from the manufactures website under Downloads Good luck Walter Grzybowski
Sep 17, 2006 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
