Question about GE Washing Machines
Water keep runing - GE Washing Machines
  • adiehiggs Jun 08, 2008
    my washer machine keep runing cold water in after it is turn off
  • 833 Answers
There are several possibilities. Most likely is a bad valve. Unplug the machine. Is the water still running? Valve is bad. Replace it.
If the water shuts off, the timer is malfunctioning.
Posted on Jun 08, 2008
Water keeps going in to the wash but not fill its draining
Check if you installed the hoses correctly. It must go up first then down about 600 mm at least.
Jan 09, 2014 | Kenmore Washing Machines
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
I replaced the radiator water pump and thermostat but my 85 jeep cherokee keeps over heating v6 2.8l
check all the water lines, coolant hoses and make sure radiator is not runing out of water, after check this, check oil level, otherwise or last thing might be temperature sensor. hope this helps good luck!
Jul 06, 2011 | 1985 Jeep Cherokee
It lets a little "soaking"
your belt went bad in dish washer replace belt. dont keep runing that like that you will burn the moter up in dish washer
Feb 15, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
The water in the bowl keep runing after the tank is full.
fill valve not shutting off water running over overflow tube set or replace fill valve flapper valve leaking replace flapper valve cracked and leaking flush valve assembly replace
Sep 18, 2010 | Toto Promenade, 1.6 GPF, Elongated...
1994 ford tours runing hot.replaced water
If you had a crack in your head you should be losing water inside/outside the engine, the same with a head gasket, check for water running down the outside of block and the exhast for excess water discharge, I know will sould stupid but did you insert the thermostat in the correct way? spring facing downwards?. The only other thing i can think of is if you have a collapsed rubber hose somewhere.
Feb 06, 2010 | 1994 Ford Taurus
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
Leaks out when it is filling.
Make sure the drain hose is higher than the top of the washer tub.
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps runing throught the GMax 580
You will need to replace it with a fluidmaster.
Sep 21, 2009 | Toto Toilet Onepiece Ultramax ...
Washing Machines Logo
16 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
