Question about Proscan PS32500 32" TV
Cant use all cable channels
The tv will only p/up 12 channels. i have basic cable and cannot program all the channels in. what can i do?
  • Anonymous Mar 23, 2014
    cant get basic cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Posted on Dec 01, 2008
I need to re-program my toshiba tv to get basic channels after i just had th cable box removed. how do i re-program it on the remote?
But u still have and pay for the basic cable service wright?Yes,just used the tv remote and push the remote menu button than go into the tv menu,go into Setup enter and go down and pick CABLE not AIR.Enter for the tv do scanning for cables channels.After finish scanning u will get all the basic cable channels.
Jul 13, 2011 | Toshiba MV13M2 13 in. TV/VCR Combo
Program Blocked errors
I was having the same problem with the constant blue screen appearing with different error codes. Here is how I fixed the problem on my Elements 19": I did a channel search. I found there were 68 analog channels and 274 digital channels. On a hunch, I went into Skip Channels and checked off all the digital channels since I have basic cable. Although the tv is HD and did pick up the basic HD channels, I choose to skip those two since I do not have a cable box on that tv and only the basic channels were in HD (about 8). I watched my tv for two hours and blue screen appeared once every 30 minutes, but the next day it did not appear at all.
I concluded that those error messages are because those channels are blocked and we have not checked them off to be skipped. When checking the Skip Channels, as you highlight each channel it will either come in or it will not. You will find the "Blocked Program" errors are coming from channels that do not come in and you will need to skip those channels.
I hope you can understand how I solved my blue screen problem on my Elements tv. Good luck!
Nov 14, 2009 | Element Electronics FLX-1910 19 in. LCD...
Can't see my cable channels!
you have to scan threw the tv in the menu to get the channels to show up
Jun 04, 2009 | Toshiba MD13P1 13 in. TV/DVD Combo
TV will not turn on to channel 4 everytime. I have a cable box and need the tv to remain on channel 4.
As long as the tv is not unplugged it should stay on the same channel when turned back on. If you have the tv plugged into the cable box, when the box is shut off it basically unplugs your tv and the tvs memory is reset. The tv should be plugged in to its own outlet or leave the cable box on and turn off the tv. If you turn everything on, cable box and tv, and have a picture, go into the tv menu and auto program the channels, it should only lock in on channel 4 since it will be the only channel the tv will receive.
May 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cable channels wont program above 27 w my basic cable
Hi classmom2,
I will be happy to help.
You have probably tried this but I will go over it anyway. If it dosn't work we will try something else.
From the video menu on the tv, select the tuning band of CABLE not AIR. Then do a Auto-Channel Search.
From what I gather you have basic cable without a cable box correct?
Let me know what you find and we will go from there.
Lone99star
Jan 24, 2009 | Sharp LC-26D7U 26 in. HDTV LCD Television
Only getting some channels to come in...
Check your latest phone bill and see if you have a basic extended package. If you dont you may have been downgraded to only get basic cable which is 2-13.
The auto program adds every channel that the television can detect.
Jan 04, 2009 | Sanyo DS25390 TV
Programing channels
Check your tv set, set it on outo program scan set it into CATV.
Apr 11, 2008 | Memorex MT1134 13" TV
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Cant access "Antenna" in tv menu to change to cable
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Feb 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Proscan PS32500 32" TV Logo
238 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
