Question about Toshiba Computers & Internet
Machine does not boot - Toshiba Computers & Internet
  • 326 Answers
Explain further please.
Posted on Jun 08, 2008
How to enable startup repair on windows 7
restart ur machine and while it is booting up press buttons F2 F4 F6 F8 F10 which will take you into the boot menu where u can select the boot order then insert ur repair disk into DVD drive then select DVD drive as primary boot option and hit enter the machine should restart again and boot up the repair process
Oct 31, 2016 | Computers & Internet
How i'll start to formate my dv6 hp laptop 2163tx step by step i'hv my recovery cd
Put the CD/DVD in the machine and re-boot it. If it doesn't readt it from the start you'll need to change the boot drive order in the machine's BIOS Setup which you get to when the machine is just starting up (look for the key to press during the boot up process). After you set the CD ROM to be the first boot drive - the recovery disk should boot the machine and get you going.
Jan 05, 2012 | Computers & Internet
Booting from usb
Check your BIOS settings and make sure they USB is not blocked in BIOS from booting the machine. By Default the Toughbook series are set to block the USB port from booting the machine at the factory.
Dec 03, 2011 | Panasonic Toughbook CF-27 Notebook
When a SATA CD/DVD-ROM Drive is removed, the system fails to boot! Crazy! I just used the drive to re-load the machine but has to remove it. The moment it is removed, the machine fails to boot pas the...
Go into the BIOS and set the BIOS configuration to its default settings. Save the changes and exit the BIOS.
When the computer restarts see if it will boot past the Windows logo.
Please let me know what happens.
Good luck.
Jun 09, 2011 | IBM ThinkCentre M50 8187 Desktop PC -...
Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to...
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
May 19, 2011 | Computers & Internet
Can i restore my asus X5DC notebook to factory settings without a recovery cd as i have my computer is saying i am infected with spyware and it wont work???
Without the CDs, no, not usually.
Sometimes a machine will have a partition on the hard drive which contains the recovery information to restore the machine but I have seen this very often. If your machine is lucky to be like this you will see a prompt to hit a key at boot up which will boot you into a menu to restore your machine. This is not to be confused with the BIOS (motherboard settings, usually F2 at boot) menu or the Windows boot menu (F8 before the windows logo appears).
Mar 12, 2011 | Computers & Internet
Starts to boot up then boots back down.
Install your Mac OS disc in your machine and start it up while holding down the C key. The machine will boot off of the disc and then you can access the top menu . Look under utilities and launch Disk Utility. Do a repair to your hard drive and then quit the program.
Before you restart, be sure to select your OS on your hard drive as the startup disk via the same menu.
See if this eliminates your problem.
May 11, 2010 | Apple MacBook Pro Notebook
Hello my boot disk is crash now. so , had to
Maybe rescue the data by booting from a LIVECD like PUPPYLINUX and transfer all files to a working hard disc. then reinstall system.
Feb 13, 2010 | Computers & Internet
Toshiba m35x-s349 turns on but does not boot
check battery power. Lots of times laptops won't boot if the battery has gone down to low. Probably has just enough charge to turn the machine on but not enough charge to boot the machine.
Nov 09, 2009 | Toshiba Satellite M35X-S349 Notebook
Machine will not boot. Sdreen message "no input signal"
When you say the machine will not boot, do you mean that you do not even get the startup splash screen during the post? And when you say you tried reinstalling, Did you get the Vista DVD to boot? If the Vista DVD would not boot the system, then activation is not the problem. Your system should give you at least a single beep during startup. If you aren't getting this far, then your problem could be either the motherboard or the power supply.
Jan 20, 2009 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
