Question about Sharp R-1490 Microwave Oven
Digital display the digital display stopped working correctly and parts of the numbers do not show
  • Sharp Master
  • 9,086 Answers
You would need a new VFD tube and we could replace this for you for about $75 total.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 08, 2008
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Microwave Ovens
Panasonic genius 1200w
You may have a failed keypad or moisture or grease on the keypad innards or on the control circuit board itself.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes if it's an over the range model.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
May 02, 2013 | Panasonic NN-H764 Microwave Oven
I have a Kenmor Elite microwave oven, model 721.66460400. The timer no longer work properly, i.e., I cannot set the cooking on button. Where would I find someone to provide parts and perfom work to get...
It sounds like a failed membrane keypad.
On some models, you have to buy a separate keypad.
I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
In other cases, you can replace the whole control panel frame assembly, which comes with a ney keypad already on it. This runs more, but it's much simpler.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
You can find helpful exploded views and order parts from the Sears Parts Direct Web site.
That model number (721.66460400) is not showing up in my search. Please check it again.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 16, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
I have a Sharp R510BK Microwave. The digital display only shows partial numbers. What part can I order to repair this?
The control unit (both circuit boards and the display) is part number CPWBFB023MRU0 and you can order it for $107.07 from Encompass here or you can call them toll-free at 866-779-5835.
Or you can have your display repaired for only $39.95 in most cases. Details are here.
Sep 16, 2011 | Sharp Microwave Ovens
Frigidaire microwave model fmv152ksa Some of the buttons on the console do not work. The number 5 does not work (if I hit timer & any other #, the # will show up, but 5 will not show up) the clock on...
If you're saying that some digits or segments on the display do not light up, then I would first suspect grease or moisture on the control circuit board.
If it's just that some pads on the keypad will not respond, I would say your membrane keypad is failing.
I would first give it a "hard reset" by unplugging it for 2 minutes, then trying it again.
If it still fails, I would remove the control panel assembly (see the disassembly video here) and inspect the circuit board for green, gray, or white residue or grease.
The membrane keypad is not available as a separate part, but comes already installed on a new control panel frame, which is part number 5304464130 which you can order from the Pros here.
To replace that, you unplug the keypad (as per the photo below) and move your circuit board into your frame.
If you need more help, feel free to contact us directly.
Jan 27, 2011 | Frigidaire FMV152K Microwave Oven
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
Sharp Microwave diplay light not working
We regularly repair these display / control units nationwide by mail for $39.95 postpaid with a one year guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Jul 07, 2010 | Sharp Microwave Ovens
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
What does F4 on microwave display mean?
This Kenmore is made by LG for Whirlpool. Confused yet? :D
F4 means you have an open humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site here, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
But Sears parts can usually be obtained for far less here by entering either the part number.
Apr 22, 2010 | Kenmore Microwave Ovens
Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
Aug 13, 2008 | Sharp R-420DK Microwave Oven
Sharp R-1490 Microwave Oven Logo
74 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
