Question about Palm Treo 755p Smartphone
Treo 755p Frozen
When I take the battery out and reinsert it, the screen shows with 8 colored blocks. Red, green, blue white down the left colomn. White, red, green, and blue down the right. Did a hard reset and a soft, nada?
  • 4 more comments
  • Anonymous Jun 10, 2008
    This phone sucks. I wish i kept my 650.
  • Nevergettogo Jun 11, 2008
    I have the exact same problem and it started on June 8th, the same day as the previous post. Are there any known fixes?
  • Anonymous Jun 30, 2008
    This started happening to my phone on June 28th it was trying to HotSync when it was not conneted to my computer. I removed the battery and reinstalled it and the color blocks showed up. I have not done a hard reset because I can't get the phone to get pass the color blocks. I am taking the phone into a sprint store today. Will post to let you know what happens.
  • Anonymous Jul 08, 2008
    same thing happened to my phone today- it used to happen on my 750 and when i taped it to the fan over night it was always fine in the morning. not the case with this one. not the first time ive had this problem with these phones- getting sick of paying the insurance fee to get a new one when the phone is just crappy
  • Anonymous Jan 07, 2009
    This is crazy I dont even have a memory card inserted how is this a memory problem?
  • Anonymous Feb 01, 2009
    I am having the exact same problem, and also have no memory card in the phone. Perhaps there is a whole batch of defective phones? I will take mine into the Verizon store tomorrow to see what they say. I can not figure out what triggered the hot sync issue to begin with.
This happend to me about a month ago, right after this, it went into the hotsync problem. where it would try to connect to hotsyc using the cradle, even though it was not connected. and I basically had no use of my phone unless I actually had it connected to the computer, but asuming that I wasnt going to be able to carry my computer in my purse, there was no way I would be able to use it. after battling it out with support tech from verizon, and the store, palm finally said it was a bad phone and put it on the system that i needed a replacement. so verizon had to honor that. well 5 days later i recieved my new refurbished phone. which was working fine until about 4pm yesterday. I am getting no audio from incoming and outgoing calls, the speakers do work because I can hear audio from videos and ringtones fine. so after the drama of hard reseting again, verizon said that it was a bad phone, and I will be getting refurbished phone #2 with in the next few days.  oh and anyone having this problem, after reading like a hundred forums, i came to find out that the connector for the usb port is very sensitive, any kind of moister, for water damage, to even having it in the restroom as you shower, can cause it to get a short in the port that it gives it enough of a charge that it's trying to start up hot sync. however the colored block problem also has to do with your memory card, but same thing, the ports are shorting out just enough to cause somekind of a malfunction. hope this helps
Posted on Jun 12, 2008
I had the same problem this morning, and after reading the solution #1 post about the problem also happening in the memory card I fixed it, at least for now. here is what I did
took out battery
took out memory card
put battery back in, now it was working correctly
put memory card back in
Posted on Jan 05, 2009
My 755 restarts when I try to get to instant messaging. Also when I try to delete mail.
leaseman
Posted on Jun 10, 2008
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
My palm 755p has the red, blue, white and green blocks what do i
NEED TO DO A HARD RESET ITS GOING TO ERASE EVERYTHING AND ITS GOING TO GET RID OF THOOSE PROBLEMS! JUST PRESS AND HOLD THE RED END BOTTON AND AT THE SAME TIME PULL THE BATTERY (KEEP UR FIGURE ON THE RED END KEY) THEN PUT THE BATTERY BACK, AND IF I WERE U I WOULD DO A SYNC EVERY WEEKEND!
Sep 28, 2009 | Palm Treo 755p Smartphone
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there....
when battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Jul 18, 2009 | Palm Treo 650 Handheld
I purchased a aliph jawbone 2 from all4cellular.com for $69.95 and it won't pair up with my treo 755p. It's not my phone because I can pair up with my wifes Motorola headset. I even tried my coworkers...
Palm Treo 755p
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Feb 21, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
Jan 26, 2009 | Palm Treo 755p Smartphone
Error 0.14
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Nov 18, 2008 | Palm Treo 700p Smartphone
Phone frozen: The screen just shows boxes of red, green, blue and white.
Just had the same problem. When you take the battery out, leave it out for 4-5 minutes. Then when you put it in and reset while holding the on/off red button, it should start. Mind did. Good luck.
Stacy
Sep 07, 2008 | Palm Treo 700p Smartphone
Dialing on 755p
Ok theres two ways to do this, heres 1 way: press menu while you our on the phone display (the button to the right of alt) use the 5 way navigator to move to the right, scroll down to phone display options. Below the Show Dial Pad/ Show Wallpaper, you'll see where it says typing dials phone number change that to typing starts contact search. This will permanently make it liek your old treo. If you wanna dial numbers press the white button to thte left of z and start dialing the numbers.
Version 2: If you dial normally it will dial numbers, if you press th white button to the left of z then type contact name also works.
hopes this help
Masalama
Feb 08, 2008 | Palm Treo 755p Smartphone
Hard reset
Remove the battery. Then, hold down the red button while reinserting the battery until it comes back up. Let go of the red button and it will prompt you to see if you really want to erase all data and go back to default.
Nov 18, 2007 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
1,214 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
