Health & Beauty Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Carl DC-95/DC-100 Rotary Paper Cutters - Health & Beauty
Anonymous
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Oct 25, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
92301
Points
999
Hi and thank you for using fixya:
What is your problem with the paper cutters?
Thanks
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Runs but doesn't feed paper and shred
Hi, If the shredder teeth / cutters arent moving, then there is most likely a broken/stripped gear or a gear with broken teeth.
If the cutters are moving, then look to see if there is something obstructing the entrance slot where you place the paper.
Good luck.
Restring hills rotary clothes line
To restring the Hills Everyday 37 rotary clothesline FD88010 you are going to need a couple of tools which include a small screw driver and a set of cutters to cut the new line cord.
You will also need to order a pack of line, which for this unit would need to be the 70m pack from Hills. Here is a link to the line pack you would need.
https://www.lifestyleclotheslines.com.au/clothesline-spare-parts/hills-70m-polycore-replacement-pack-grey-FD903530
Here is a great video on the process to restring the Hills Everyday 37 rotary clothesline FD88010
If you need to access the Everyday 37 manual you can do so here and download it.
Hills Everyday 37 Rotary Clothesline Owners Manual FD88010
Hills line clips could be something that you may also need in the restring process as these do tend to break on the older models of this unit. Below is a link to the Hills line clips that fit the Hills Everyday 37 FD88010 model.
Hills Rotary Clothesline Line Clip Pack of 6 FD902506
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
1helpful
Error code sc 460 on a ricoh 240w large format printer
It is a DC seperation corona error, open up the unit (like a ****) and check for paper clip or other such stuff on/around the long wire on the lower part of the printer otherwise call for service, sorry. -Carl
2answers
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
I have a ccs5000 shredder that squeals now and then. I have checked all the gears and belts, found no troubles there. I have ran a sheet of lubricant for shredders throuhg the cutters and no change. We...
This a cross cut shredder right? Its job wears out these blades, sooner if not lubricated during its life. Replacing the blade assy. could get costly.
-Carl, please let me know if this helps.
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
