Question about GE Washing Machines
We bought a washer yesterday. When I went to fill it up this morning the water would not fill but just drains, while the water is running, please help, I think it is something simple/
  • 413 Answers
The drain hose is too far down the drain. Pull out excess hose from drain and leave only 8 to to 12 inches. Using zip tie or other method, secure drain hose to water hoses to prevent drain hose from jumping out.
Posted on Jun 08, 2008
My LG washer/dyer fills up with water after its done running, it washes and drys then fills up
something is holding the input valve open small pieces of rust etc. will do this .that is why they put screens in the ends of the hoses
Sep 23, 2017 | Washing Machines
I have standing water in drum every morning.
Without further information, I can offer three possible issues:
1. The fill value is furred up and is not fully closing (diagnose this by turning off the water after use at the isolator valve - and if no water is getting into the drum overnight, then it is a filling problem and you needn't read on - as opposed to a draining problem in which case read on!)
2. If you have a long drain hose running along the back of kitchen units, perhaps it is running back into the machine
3. Have you installed anything else into the same drainage pipes - such as a waste disposal unit or another appliance - that may be pushing water down the drain so fast, that some returns into other connected appliances?
Good luck
Sep 20, 2014 | LG Wm2688hnma Front Load Washer wm2688hnma
Drum fill with water
If your machine outlet pipe is connected to the sink trap (many are these days) it could simply be that water from the sink is draining into the washer if it is connected like this ensure that where the outlet pipe leaves the the trap it goes up and does not run level or down if the water in the is dirty this is the problem failing this water vavles are passing water when the machine is off
Mar 03, 2014 | Whirlpool 3.5 Cu. Ft. White Front Load...
My used Kenmore washer fills with water then the water level drops downto about the half way level in drum. I just bought it used and installed it yesterday. Could the water be siphoning out into drain...
It sounds as if it is siphoning out the drain pipe.You have to get the drain pipe up to the top of the washer and also be sure that the pipe is a little bigger than the drain hose or it will siphon. Hope this helps.
May 13, 2011 | Kenmore 24032\24036 Top Load Washer
We just bought a new front loading washer and dryer Whirlpool model # wfw9150ww. (purchase date 12/22/2010) It has been working fine until yesterday....The washer fills up..(with too much water in my...
It means the washer is failing to completely drain. If you can find no problem with the washer drain hose and the volume coming out is ok, then you may need to replace the CCU (central control unit)
Jun 19, 2017 | Washing Machines
Whirlpool Duet Washer Leaking
Hi, If you are getting water in the washer without it running, the inlet mixer valve is going bad. When you run a load, does it finish spinning and all the water is out? I hope this helps you. It is not an expensing repair. I can walk you through the repair if you would like.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak prob
read the owners manual or the installation instructions in the drain standpipe height minimun requiremants
Sep 15, 2007 | Whirlpool LSR5102LQ Top Load Washer
Washing Machines Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
