Question about Nakamichi MF-51 5-Disc CD Changer
Its simple, since ur using a cd changer u should make sure when u burn the songs in the cd's it should be in cd-audio format and not mp3 format.
Secondly after burning the songs make sure that the cd is closed and not in multisession mode.
after trying the above solution reply me...
issy2, I recorded the cd tracts as .cda files, no mp3's. Also, I did not use a multisession mode. When I play the cd some tracts will play just fine while others will skip, rewind, or just cycle within the tract. Store-bought cd's play fine, no problems. I have tried "copying" the cd's, and I have tried ripping the cd's to the hard drive and choosing tracts for a copy. None of the "copies" work perfectly.
    Master:
    Sergeant:
  • 460 Answers
I suggest you should give your audio player for general service..!!
Posted on Jun 09, 2008
Nakamichi mf 51
It does not look like this device might play any CD-R or MP3 and is very unlikely that can be modified because of the way it was design. It does not like to play copies only original CDs.
My suggestion will be to buy a device that is compatible with CD-R and MP3 as well.
That could be a cheaper way then trying to modified it.
May 04, 2008 | Nakamichi MF-51 5-Disc CD Changer
Won't play recorded cd's
Try a different brand of recordable CD. Some players are sensitive to the color of the disc itself. This is usually only with older players, but I have seen this as a problem in the past.
Dan
Apr 23, 2008 | Nakamichi MF-51 5-Disc CD Changer
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
No Play No Eject
COMMON PROBLEM
OPEN IT UP AND REMOVE YOUR DISC AND THEN THROW THE PLAYER AS FAR AS YOU CAN.
Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
Nakamichi MB-100 Disk error
VERY COMMON PROBLEM
THE BEST THING TO DO IS THROW IT AWAY
Jan 11, 2008 | Nakamichi MB-100 6-Disc CD Changer
Try this link. It offers resistor changes which are designed to fix your problem of inability to play any CD R. on that model Nakamichi. jacknz0 http://home.cogeco.ca/~niteowl/Nak_MF51.jpg
Dec 31, 2007 | Nakamichi MF-51 5-Disc CD Changer
Nakamichi MF-51 5-Disc CD Changer Logo
161 people viewed this question
Top Nakamichi Car Audio & Video Experts
olayoju victor
xxxxxx xxx
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
