Question about Microsoft Windows XP Professional
HP NC 6000 windows 2000
I stupidly started compressing hard drive to save space and i shut computer down before it was finished now when i try to start computer i m in a loop boot manager compressed press cntrl alt del ,i cant get get into safe mode with F8. I have Hp's nc 6000 windows 2000 installed.... what do i do????
  • Microsoft Master
  • 13,433 Answers
1st try last known good configuration
if that doesn't work
then get the setup cd. start the setup and press r or enter repair console when asked. it asks for your password, login, then run chkdsk make sure it does the check even if it says the disk is marked clean. I dont remember which switch it was you can see them with chkdsk /?
Do that and try starting windows again.
If that failes do a repair install from the windows setup.
Posted on Jun 08, 2008
Why does it take my computer a long time to boot up, loading, and shutting down?
indicates that then hard drive is on the way out
first step is to save everything onto an external hard drive
then take it to a computer repair shop for an inspection
check how much space is on the hard drive because if you have a lot of junk on it , that slows down the start up and shut down p[rocesses
you can go to device manager and do a defrag of the hard drive to free up space
Aug 09, 2017 | Time Computers & Internet
How do use Verbatim to back up files
Which operating system ?
Determine how much space you need. The first step in backing up your hard drive is to figure out how much space you will need to back up all of your files. You can do this in a couple of ways. Find out how large the hard drive is on your computer first to see if you can back up the whole thing. Click on "My Computer," right-click the "C" drive and select "Properties." This shows the approximate of your hard drive, how much space is actually taken, plus the space used by your operating system. If your hard drive is manageable (the space actually taken), back up the whole thing. Your second option is to create a file called "Backup" and copy all of your important files into it. Right-click on the folder once everything is copied over and choose "Properties" to find out the of the folder. This is how much space you will need to back up your important files only. Choose a backup method. Choose either an external hard drive, data disks (CDs, for example) or use an online backup service. Plug the flash drive or the External Hard drive into your computer's rectangular-shaped USB drive. Wait for Windows to recognize the system. Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration. Open the drive on your computer. Open the "My Computer" directory if using Windows XP or the "Computer" directory if using Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it. Transfer files to the flash drive. Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background. Open the folders or locations of the files which you want to save to the flash drive. Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window. Release the mouse button to let the files "drop." Close the windows and directory locations when finished. Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option. Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section. Click the "Save" button to save the file onto the flash drive. Close the windows and files when finished
Apr 03, 2013 | Verbatim Computers & Internet
Can't find back-up folder
You might have to create a folder you can do this by right clicking in the backup destination drive selecting new folder and name it lets say Back Up 2012 for the excercise.
This shows the approximate size of your hard drive, how much space is actually taken, plus the space used by your operating system.
If your hard drive size is manageable (the space actually taken), back up the whole thing.
Right-click on the folder once everything is copied over and choose "Properties" to find out the size of the folder.
Hope this helps.
Nov 16, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
Does storing a lot of pictures on my PC cause it to run slower?
It could, depending on how large your hard drive is. Side note, if these are important, back them up so you won't lose them.
One way to save space is to put your hard drive in a compress mode.
Go to start, computer, select the hard drive, right click then under properties click the box that says "compress to save space". It will save space and also help it run faster.
Oct 17, 2010 | Dell Dimension 4600 PC Desktop
Can I increase disk space for Presario F762NR notebook? And if so..how. Thank-you
You can compress the disk and gain a little room which might meet your needs, otherwise you can buy a new disk and install it. I have cloned many laptop disk drives onto new ones. It does take some special cables and and a desktop computer to do however.
Before I do either, I'd try a disk clean up. Turn system restore off then back on to delete all the SR files. Down load CCleaner and run it against the disk and run the registry cleaner.
http://www.piriform.com/ccleaner/download
Disable Hibernation and delete Hiberfil.sys, if the space problem is critical on your System Drive. Its a hidden file on the root directory of your system drive. Open Control Panel. Type Hibernate in the search bar. Select turn Hibernate On / Off.
If you want to try the compress, double click My Computer, right click on the C:\drive, PROPERTIES, check Compress this drive.. This will take awhile so don't turn off the computer or let it shut down. Some say you should not compress the windows folder but I've never had a problem and they slow down is almost not noticable.
Aug 04, 2010 | HP Compaq Presario F762NR Notebook
MY HP COMPAQ NC 6000 LAPTOP request a Drivelock HDD bay password
Hi kala_mumbe,
I know how you feel as my HP pavilion has had the same blue screen ansking for the 'drivelock multibay password' . the good news is i have fixed it just 5 mins ago.
I think that you have to get into the bios first. Lets see if I can show you how I helped it to boot up:
  1. at the blue screen I pressed the F10 Key which took me into setup
  2. i then selected the security tab
  3. and then I think I selected drivelock password
  4. and then selected the "Notebook hard drive" item where I tried to disable, with no success
    PLEASE NOTE: at this point I noticed that each time that i tried to disable the password it kept returning to the item 'Notebook hard drive' . I thought to myself that maybe this is the password and not just an item on the list, so I carefully wrote down .. Notebook hard drive .. taking note of capitalization and spaces and then exited setup.
  5. I then noticed that there was nowhere to enter the password so i carefully typed .. Notebook hard drive .. onto the keyboard, and waited. After about 1 min a small 'OK' appeared inside the blue box and my heart leaped for joy inside my chest.
  6. I waited... and a black screen apeared with the wite cursor blinking
  7. and I waited... this time about 5 mins passed and then windows started to load. Thank God!
I hope you get some joy out of this post and it's not too late for your Campac Laptop.
happy, happy
Darryn Hope
www.darrynhope.com
Apr 19, 2010 | Acer Aspire One PC Notebook
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
When sending print job on a 1315 psc 3 pages go in blank
  1. Shut down the computer.
  2. Unplug all USB devices other than a keyboard.
  3. Start up the computer. When the brand logo appears, press the F2 key to enter the System Setup (BIOS) program. If the Windows screen appears, wait until the computer finishes starting up, then shut down and try again.
  4. Press the Down Arrow key to highlight Integrated Devices (Legacy Select Options).
  5. Press the Enter key.
  6. Press the Down Arrow key to highlight USB Emulation .
  7. Press the Space Bar until the option displays No BOOT .
  8. Press the Esc key twice to go to the Exit menu.
  9. Ensure that Save Changes and Exit is highlighted, and press the Enter key.
Nov 25, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp Pavillion ze4900
the way things sound, you definately need a new hard drive and battery. as for saving the information, thats a little dicy. its more than probable an expert can, but it may turn out to be difficult. As for where to send it, i'd say take it to the closest best buy and they will be able to help you amptly.
You will only have to upgrade to vista if you buy a new computer as a whole. you can still stay with 2000 if thats what you prefer.
Jun 03, 2008 | HP Pavilion dv4000 Notebook
Boot manager compressed
You are stupid!!! of course there is another way!!!!
http://answers.yahoo.com/question
/index?qid=20080612115923AAgIovt
Guru my ***!!!!
May 04, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
