Question about Equator EZ 3612 CEE Front Load Washer/Dryer
EQUATOR 3612CEE WASHER DRYER/NOT DRYING
THE WASH & FAB SOFTENER CYCLES WORK FINE. WHEN THE CYCLE HITS SPIN I HEAR A CLICK, BUT NOTHING HAPPENS. THE RED LIGHTS FLASHES AND THEN DISAPPEARS. I'VE HAD TWO GOOD YEARS WITH THIS, AND NEED TO GET MY $939 WORTH OUT OF THIS APPLIANCE!!! CAN ANYONE HELP??? THANKS!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 37 Answers
First of all you may want to reset the unit, let me know if you need the procedure and after reseting if the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Posted on Feb 26, 2010
The machine will fill with water and run through the first part of the cycle, then stop. If I turn the setting dial to the next setting the machine will start, but does not pump out the water. At each step...
Have exactly the same problem. At first thought it was broken drain pipe--as I found broken drain pipe searching for a fix for this--coincidence? Anyway, drain pipe fixed, and unit still will not enter spin mode. When unit gets to spin mode, there's an audible click (solenoid), and the unit will not spin or drain the water.
All else is working fine.
What part should be replaced?
Nov 16, 2009 | Equator EZ 3600 CEE Front Load Washer /...
The wash cycle doesn't work, but spin cycle works!
Did you ever find out what was wrong with your washer?
Mar 23, 2009 | Whirlpool Washing Machines
I have an equator washer/dryer combo. It seems to have a few problems. The washer doesn't spin during the spin cycle, although it spins during the rest of the wash cycle. The pump is making a weird...
I have one of these things, too, an EZ 3612 CEE. I've replaced the pump on mine, but I am in no way an appliance technician. However, your problem seems like an electronics problem to me and the service people I've spoke to about this machine have told me that the main circuit boards in these machines fail regularly. That has yet to happen to me. I would suggest calling the equator service number. You'll be connected to some technician in India, almost certainly. But my experience with these guys has been great. They have VERY patiently talked me through a couple of different diagnostic procedures and solved some problems. Don't have the phone # just now but you can google equator appliance and get it.
Jun 23, 2008 | Equator Washing Machines
DRYER NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Apr 22, 2008 | Equator EZ 3612 CEE Front Load...
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Black marks
throw a clean pair of old sneakers in the dryer with the clothes. this should not allow the clothes to stay in one place during the entire dry cycle
May 25, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ 3612 CEE Front Load Washer/Dryer Logo
108 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
